Tapping Rear Brake in Mid Air
Edited Date/Time 12/22/2014 2:03pm
So I have never really had to because I have only been to the track a few times, but when starting to hit bigger jumps and you maybe end up front end high, and they say to pull the clutch in and tap rear brake, are you holding the clutch in until you land? OR do you just pull in clutch, tap rear brake with clutch pulled in, and then when you level out let go? If someone could tell me exactly step for step that would be great. Just trying to understand better
Thank you!
jhansen510
GREENFIELD, MN, USA
12/18/2014 1:03pm
Get more forward on the bike. You should not have to break check except for certain situations. If you have to do it on every jump it's bad technique. That said I would pull clutch slightly, tap brake, let clutch out and pin it as you land
seth505
SD, CA, USA
12/18/2014 2:35pm
It's one of those things you just learn by feel. But like he said above, just slightly pull in the clutch as you are stabbing the rear brake. I've also done it while opening the throttle slightly to ensure I don't stall out, just depends on the jump/situation.
moore433
Denton, TX, USA
12/18/2014 3:40pm
Just start learning this technique on a small jump first please! If you don't do it right and kill the motor trying this on a big jump, it's not pretty.
Personally, I don't use this technique unless I have to, just because it can go bad fast.
Be careful bud.
JW381
Harrisburg, OR, USA
12/18/2014 5:03pm
It's something I rarely ever do, but yeah I don't think you need a ton of clutch pull, just get it engaging and give the brake a tap/stomp then let the clutch out and blip the throttle
12/18/2014 7:14pm
start on a safe tabletop. you wont see pros do it very much,only when needed. seems like it was bigger before everyone started front low,scrubbing etc.
12/18/2014 8:00pm
Okay I see, seems like it's something you don't do much from the sounds of it. So the most common issue then just sounds like front end down and all you do there is just give it gas right?
BD233
DFW, TX, USA
12/19/2014 7:03am
Yea, front end low just get on the gas. The only time I tap the rear brake is when seat bouncing , it usually sends me a little nose high..so I tap it to bring the nose down. I just pull the clutch, tap, blip, and let out the clutch...
mx621
12/19/2014 10:42am
seth505 wrote:
It's one of those things you just learn by feel. But like he said above, just slightly pull in the clutch as you are stabbing the...
^^. try not to force it... it is technique the comes with time.. I can say I mostly tap the back brake on seat bounce jumps and then very little bedsides that. I would say you need to become pretty comfortable jumping before you try it.. other wise you could be headed over the bars...
Dragoo168
12/19/2014 11:44am
I agree with the the above, and while it isn't a bad idea to experiment the technique on small jumps first, get it in your head that it is primarily something to utilize in an emergency, and not a regular mid-air adjustment, LOL! The key is to pull the clutch to not stall the engine, as stated above, and you want to time the throttle "Blip" with the tap of the brake. Learn to do all of this quickly, in one motion,...maybe say "Braap" to yourself, and learn to do this technique in the same timeframe, and if you don't already know, you should be on the gas prior to landing as well. (Unless there's a corner or something at the landing point, Hah! While you're at it, focus on your body position as you approach the jump, to figure out why your takeoff is pitching you that way. stay in a central/neutral position, knees bent, off the seat, with enough throttle to launch smoothly,...once you become comfortable, you'll begin to notice wether your suspension is set up properly for your style of riding, and functionality on the track as a whole.
12/19/2014 3:46pm
skills 3 i think by transworld. pretty good covering all the basics.
hoova
12/20/2014 7:17am Edited Date/Time 12/20/2014 7:19am
I think this is important to learn until it is instinctive as you will go nose high at some point. I come off this way a couple years back on an 80ft table table (different line), got a bit all over the place and missed the brake (don't ask)... It hurt alot and more importantly damaged the bike considerably (bent the subframe badly, destroyed plastics including airbox, destroyed brand new silencer). my left ass cheek was swollen for 5 month... Had to sleep on my right side and if I rolled in my sleep it would wake me (every night). Just Luckily it wasn't a serious injury.
MotoX85
Centralia, IL, USA
12/21/2014 12:17am
Proper technique is to never hit the rear brake in the air, but some jumps require it. Pull in the clutch and tap the break and then depending on the attitude of the bike, you may have to continue to hold it in or if done properly, dump the clutch and pin it about a foot or two before landing
Markee
Suffolk, VA, USA
12/21/2014 5:39am
Being a new rider you need experience to refine your "internal" gyro that tells you front end to high, front end to low.
motomike894
Waterloo, IN, USA
12/21/2014 6:53am
Personally if I get funky in the air I just grab a handful of front brake and problem solved.
DoctorJD
Somewhere in..., GA, USA
12/21/2014 6:54am
Like others have pointed out, it probably a good technique to learn, but don't use it as a crutch. On my four-stroke, I rarely brake-tapped, as engine braking was usually enough to do the trick. Since switching back to a two-stroke, I find myself doing it a little more. Mostly on jumps without a lot of run-in where I have to stay on the throttle longer. Whatever you do DON'T KILL THE ENGINE IN THE AIR. I let my finger slip off the clutch a few weeks ago (killing the engine) and almost ate crap. Actually, I think it would have hurt less had I crashed. Slammed my chest against the crossbar, feet off the pegs, one hand off the bars. It was spode-tastic to say the least.
motomike894
Waterloo, IN, USA
12/21/2014 7:07am
Another solution is to downshift mid flight if your in third go to first and don't mess around about it you ram that shifter hell I do it so much I stripped my shift shaft and ripped lever off my 15 crf already
jhansen510
GREENFIELD, MN, USA
12/21/2014 2:43pm
A bit of advice. Do not listen to anything the guy above me says! You trying to get this guy hurt and destroy his bike? Come on man. No reason to do any of the things you stated!
motomike894
Waterloo, IN, USA
12/21/2014 7:01pm
Lmfao the fact you would actually even begin to think I was being serious is scary
TanHner36
Houston, TX, USA
12/21/2014 8:04pm Edited Date/Time 12/21/2014 8:06pm
braaapppp, clutch, brake tap, brappppppppp
Try to stay a little loose when you do it too The only times I ever do it are jumps out of corners or big booters, times that you're really on the gas hard going off of the lip. Try it over a small double or table (something that you won't go down if you land with wheel stop) once you're comfortable take it to a bigger jump.
jhansen510
GREENFIELD, MN, USA
12/22/2014 1:23pm
It's all good. I don't think it's funny to joke about something that could potentially hurt someone.
Joko
Haddam, CT, USA
12/22/2014 2:03pm
Would it be easier to brake tap with a Rekluse clutch setup, then you wouldn't have to use the clutch when tapping mid air?
Post a reply to: Tapping Rear Brake in Mid Air
