Wolf Creek, OR
just James
4/11/2013 5:03pm
4/11/2013 5:03pm
4/12/2013 10:31am
What is it that limits the rpm that 2 strokes turn? If a 250F will turn 14, 000 or so, why wouldn't a 2 stroke? Do they just become inefficient at high rpm, or do they not function properly with the short stroke required for high rpm?
i think you kinda answered your own question . i would think ,if the 2 stroke could rev out higher rpm's,it would prob. be flat on the bottom end power even more.or on top,for that matter,depending on porting design .
But what do I know...
-Steve
I had also wondered if the bearing design/lubrication might have something to do with it.
And yes, I do know that at least some of them do have a rev limiter.
no,wait.my jet ski had msd ignition chips w/ optional rpm max's.
are we ever going to see you do your magic again?
If ever you you decide to grace the insides of another 2 stroke engine, I'll be waiting in line.
Long time happy customer and testimonial in waiting right here. (not that you'd need it anyway)
I know there's no money in making engines scream, but there sure is joy.
Glad to see you getting a little taste of moto.
Ian
In short, because of the way a 2 stroke piston location controls the opening and closing of the ports, a fairly long stroke has to be used to control and separate those functions. This greatly increases piston speed over a short stroke engine at identical RPMs. But the 2 stroke doesn't have the option of a real short stroke like a 4 stroke has.
The other issue is it just takes a certain amount of time to move a mass of fuel from down in the crankcase in to the combustion chamber. The higher the revs, the larger the transfer ports have to become to flow the needed fuel in a shorter window. In turn making the engine a pig w/ no port velocity at low RPMS.
Lastly, it's just design for the application. If they make the motor rev too much, the torque will really suffer and that's just not useful for our application. That said, a 4 stroke by design will rev higher than an equivalent 2 stroke.
Can you make a 2 stroke rev? Sure, but w/ trade-offs.
I think when some people argue that a 2 stroke of equal displacement isn't a fair comparison to a 4 stroke because it fires 2x as often, they need to take in to consideration the fact that the 4 stroke can turn way more RPMs making up for the majority of that disadvantage.
As far as rev limiters go: My stock 250s I use to bang the choke point about 1x per lap. It sucks and will practically throw you over the bars. As a 300 I was hitting it multiple times per lap, I really didn't like that and I had to regear to deal w/ that. As a stroked 314cc however, the same engine revs insanely high and I have yet to hit the choke point. I guess my point is that they don't have a rev limiter but it's controlled by the flow of the engine and it sure feels like it's electronic, but it's not.
They dont have a spark plug, just a glow plug for cold starts.
they ignite due to the pressure in the cylinder.
A 2 stroke motocross engine simply doesnt need to rev that high. A 4 stroke only ignites once in 2 crankshaft turns. a 2 stroke once in one crankshaft turn.
So the 4 stroke basically needs to have twice the rpm of a 2 stroke.
Post a reply to: 2 Stroke tech question
