- Pick trends
- Create a private league
- And more!
You can find me on Facebook:
https://www.facebook.com/groups/179257569231617/
Or at my web forum
http://www.kxguru.com/ where I have a bunch of kx500 specific info.
Remember, no matter where you are at, you can always learn new things...
And I want to learn everything good
It was a total shocker as we had no idea MXA was doing such a thing.
I'm glad to see that we made an impression.
Motocross Action Incredible Two Stroke Hall of Fame
THE BEAST!!
So what better part to try it on then my back up 2 piece clutch cover..
https://www.instagram.com/p/BihixxCgv0d/?taken-by=ransom_kx500af_build
Looking fw to seeing that. Always wanted to see real world dyno results if those turbo cranks really work & if so to what degree. Keep up the great work!
KX250 Turbo crank
In short 7HP in the mid range and 5 on the top.
And that is with a worn out engine and fine tuning left to do
We will be doing several mods and yes, a new top end.
And we will be running each mod on the dyno to see what we gained or lost.
Here is a link to the KX500 Turbo crank testing:
KX500 Turbo Crank
I have to admit.... I was very skeptical...
But, we got 20% in the mid and 15% on top...
Don't run out and buy a Turbo Crank... First, they are not all created equally and second we are still testing.
But I have to admit, at this very early stage of testing, I am very impressed.
Jetting wasn't bad but we had to put aside much of what we know about jetting a naturally aspirated two stroke and keep pushing it leaner. Steve Parris told us that we would be shocked and we were.
The starting jetting looks coco brown and we thought perfect! Whoa, can't believe it... But no power...
So down we went a step at a time. We gained a little power each time but the color never really changed.
After about 2 hours and many jets swaps we lost power.
We checked the plug and it was a little more grey then before, so we backed it off one step and 5th gear wheelies happened again
We still have some needle work to do so I think we may get a little more mid range but I think the top end is as good as we can get.
Monday morning we are headed to a high tech dyno to verify what we recorded at the older dyno.
After all, why not verify :-)
So testing and tuning will continue to see what happens.
But at this moment... I have good feelings about this.
1998 KX250 Turbo Crank Build
7hp in the midrange and 5hp on the top end
Who is EC Birk?
I've had some awesome mentors over the years and still looking for more
And did you build it?
Before..
During..
Almost done..
But... we have many things to try to improve the performance.
We have not tried any mods as of yet but we will in the near future.
We are not giving up on it but it will take some time to see if this mod is viable on the 500.
On the 250 we haven't done anything more other then ride it.
Mid to upper power range is lively
The bottom to mid has more torque.
The next step will be to replate the cylinder and put a new piston in it.
Then, run it on the dyno again.
We believe that with some more testing and tuning we should be able to make some more gains.
I'll keep this thread up to date as more info becomes available.
Everything is lining up so we are very close to disassembling and powder coating...
Looks sweet..
I had to try a green one as well..
Unimpressive to say the least but it's a big step forward..
Post a reply to: JUST ANOTHER 2016 KTM 250SXF CHASSIS KX500 ENGINE CONVERSION GONE MAD!
