yz125 engine issues
sostoked
Twentynine Palms, CA US
Edited Date/Time 4/15/2023 6:09pm
03 yz125 used for desert racing (yes i know not the best idea). B level. Thought my jetting was pretty good. This piston and ring had 11 hours. seem to keep having a version of this issue. deteriorating head, cylinder, piston or all three like in this case.
To me it just looks like it got too hot. Thoughts?
27D48FE0-E72C-473A-95A1-7B65CF3F7F06.jpeg?VersionId=zRauCxBg.0vs6we
 6B722003-2591-41DA-AD0E-5BA195E30995.jpeg?VersionId=m2RTRixKpFqpvGflI
sostoked
4/15/2023 6:08pm
A3185121-E784-4225-9F5F-8D3C9D265BC4.jpeg?VersionId=SS
seth505
SD, CA US
4/15/2023 6:37pm
No experience desert racing but all I can say is with my 125s, I've definitely sided a little on the rich side for main jets when riding sand/fast tracks. Stuff like Cahuilla or Pala main track out here in CA.
crmx105
Dunnellon, FL US
4/15/2023 7:10pm
What fuel are you running?
sostoked
4/15/2023 7:27pm
pump fuel 32:1 maxima castor. using a lectron so i couldnt tell you the size of the jets.
AJ565
San Antonio, TX US
4/15/2023 7:34pm
I have no experience with that type of riding, but I’m sure you’re wide open a lot of the time so you’re going to need to be on the richer side. Kinda like 125cc shifter karts so they don’t melt pistons running wide open all the time. Way different jetting setup for that kinda thing.
sandman768
Saratoga Springs, NY US
4/16/2023 5:51am
Looks like serious detonation. After it’s all rebuilt, vacuum test engine, make sure no air leaks. Jet richer and work your way down to a safe leaner setting. Use better fuel, start with 50/50 C12 & pump. You are asking a lot of a high revving 125 in the desert on crappy pump fuel.
FGR01
AZ US
4/16/2023 8:52am
Yes, that is serious detonation caused by by way too lean for that type of riding.  Which model Lectron are you using?  Unfortunately, Lectrons are generally very lean which is why guys love them for tighter style off road riding.  They don't load up, are always crisp, and get excellent mpg's.   All of which is not what you want for wide open desert riding on a 125.  If you have the H-series, it does have a power jet than you can open up to richen the larger throttle, higher rpm situations which would help this problem some.  It is very sensitive.. so be careful.  Might only take like 1/4 turn more open.
Bruce372
4/16/2023 10:25pm
Major detonation! Sometimes you can hear and feel it, sometimes it's a silent killer.
Like everyone said,  more octane and a regular carb with a bigger main jet!!!
sostoked
4/17/2023 8:51am
ok really appreciate all the feedback. looks like lectron may not be doing me any favors. so ill switch back to the regular carb and a big fat main jet. also maybe some good fuel if i can find it.
sostoked
8/24/2023 8:22am
IMG 0935 0.jpeg?VersionId=IfQri4sgS4I0qN4C
sostoked
8/24/2023 8:24am
Ran another top end with 100LL and a far richer needle and power jet (lectron). Everything seems pretty oily. How does this look? Should I go more?IMG 0934 0.jpeg?VersionId=sGQlczChz be0CNZ4oEzyC
FGR01
AZ US
8/24/2023 9:22am
How is it running?   Does it feel OK?  Excessive smoke or spooge?
MxAddic
NY US
8/25/2023 8:28am
Looks pretty safe to me.
Post a reply to: yz125 engine issues
