Ktm 350 notchy shifting
Just bought a 2020 sxf350 and it has a wierd shiting problem. its like its 2 small stepps between each gear. is anyone familiar with this problem ?
FGR01
4/26/2025 12:16pm
Needs to come apart and be inspected.   Might be something loose or broken in the shift selection mechanism on the right side.
AJ565
San Antonio, TX, USA
4/26/2025 1:30pm
What brand, weight and last time you changed the oil?
willbilly
Corpus Christi, TX, USA
4/26/2025 8:00pm
The shift “star” detent is on the clutch side at about the 5 o’clock position. Sometimes they will come loose.
4/27/2025 12:37am
thanks guys. i will be changing to steel oilpump so at same time i will check the shift mechanism
Factor E
So Cal, CA, USA
4/28/2025 9:06pm
Check the points on the shift shaft that move the star  They tend to get rounded and cause your problem
5/2/2025 6:34pm
My 20 350 had a hard time going into gear and was doing something similar to what you are describing. The shift star had some burrs on the edges and the points were rounded a bit. The shift shaft was rounded like the Factor E said here, plus I think it was a wee bit bent. So I replaced those 2 items and it shifts like butter now. Luckily you don't have to split the cases for either of those two parts. I was replacing a crank so I did have the cases split when I replaced mine. Should be an easy fix for you.
Post a reply to: Ktm 350 notchy shifting
