Houston-ish, TX, USA
Is there a tool made for these somewhere? Or just use a pin spanner?
Race Tech TFCT PS21040.
Awesome. Looked there a few months back and didn’t find anything.
Rocky mountain/Tusk makes a ton of good suspension tools also
T14099
I bought a socket off RMATVMC that looks like it has similar fingers to that that unscews the inner cartridge from the main cartridge on a stock KTM fork.
The diameter of the circle of "fingers" for the stock AER forks (right) is larger than on the WP Pro (left, cone valve and 6500) forks. Basically, the diameter is smaller since there's an external preload adjuster and the cartridge fits inside that. Also, the Pro forks will not accept any tool with 4 fingers since there's only 3 slots.
Does anyone know where to find a shaft block tool to hold the cartridge for servicing. Thanks
I don't want to derail this post, but just picked up a set of these and wondered what you thought of them? I have some CV as well. J
ps- ridejbi has some clamp blocks
They look pretty much the same as the showas on my 2002 rm125 lol.
I've not seen the cone valves, but the construction looks very similar between the 6500s and the cones.
I did manage to also source a set of 6500s from a friend that is getting cones... managed to find the cartridge holder and race tech base valve tool since they need to be opened up to install the 10mm shortening spacer for the husky. Ended up going a different path with regular length and look forward to trying them.
To me, the cone valve looks like a glorified check plate so probably all that intital bleed or blow off is why people like the cones.
Do you know if these 6500 cartridges will fit in 4cs forks? Want to build a full fork set up.
No idea, probably not... unless you buy newer lugs. They definitely don't fit in the 2016 thru 2019 aer fork.... unless you buy kit with newer lugs.
They are a lot like a check plate with less flow restriction (presumably). I would also suspect the opening is more predictable compared to a shim bending.
Are you planning on fiddling with your set of CVs?
I am eventually and would be interested in your findings. There is a fair amount of info on setup (cone, preload, base valve, etc) on Thumpertalk, but most is a few years old.
Found the stock settings here (don't worry, link is clean):
https://d2akct5dekqm4p.cloudfront.net/84/media/pdf/dok-wp-sl-18150u07set-sl-sall-awsg-v1-26266.pdf
Hi Erik, I have the 6500 inserts and trying them first time today.
I really hope I don't have to mess with them. If I do, I might even send them out. After years of working on SSF showa and AER, I had forgotten what a pain twin chambers are.
On cone vs check plate, you are right the cones should give more precise control of flow... but remember a check plate can have flow control by how far it opens and also the rate of opening controlled by the check valve spring. Maybe that doesn't matter if the check plate opens beyond the flow of the piston and maybe this is where the cones shine???
Post a reply to: Inner cartridge removal on XACT Pro/ WP 6500 inserts
