High compression piston
Was thinking about putting a 13.5:1 high compression piston in my 2023 KX450..stock compression ratio is 12.5:1 So a one point higher compression ratio.. Right now my bike has a pro circuit ported and polished head..full pro circuit exhaust system..no toil pro intake kit and a Vortex ECU map by twisted development set up to run on VPU 4.4 race gas.. My question is Will the higher compression piston make a  noticeable difference.. and what other changes will I need to make to my bike like ECU tuning ect..Thanks.
skypig
Caloundra AU
11/22/2025 6:34pm
Ask Twisted? Or Pro Circuit? They have skin in the game, and experience.
willbilly
Corpus Christi, TX US
11/23/2025 6:32pm
More compression will give more power everywhere. If you ride at 4k feet or below you may have to increase octane to 91. It will not require a mapping change, but may benefit from one.
11/24/2025 11:44am
Was thinking about putting a 13.5:1 high compression piston in my 2023 KX450..stock compression ratio is 12.5:1 So a one point higher compression ratio.. Right now...
Compression tends to add power from top to bottom. How much depends on many different things. A HC piston will add more power to a matched ported head than a stock head. Marginally but still more.
I can't think of any reason not to just go give it a try if your needing to do a piston anyways.
Post a reply to: High compression piston
