Engine mount torque sequence on KTM/GasGas/Husq 450
no_fun
Masontown, PA, USA
I’m trying to reduce the vibration on my 2022 GasGas MC450F by re-torquing the engine mounts in the proper sequence. I’ve been dealing with the top mounts getting a little loose after a ride too, so I know some new Loctite is needed as well.
I’m not finding anything online or in the owner’s manual for the proper sequence to tighten these bolts – just the torque specs.  Can anyone share the proper way to go about this? Maybe it doesn’t matter?
gasgas seq.png?VersionId=Yt00Hlc3RwRaLlWdQMVWKrWpEbw
DynoDan22
Victorville, CA, USA
5/5/2023 7:22am Edited Date/Time 5/5/2023 7:25am
The proper sequence for torquing the engine fasteners are:
1) swing arm axle nut (74 ft-lbs)
2) lower engine mount (44.5 ft-lbs)
3) forward engine mount (44.5 ft-lbs)
4) qty 2 top head stay torx bolts (18 ft-lbs)
5) lower head stay torx bolt (18 ft-lbs)
no_fun
Masontown, PA, USA
5/5/2023 7:51am
Awesome. Thank you
sandman768
Saratoga Springs, NY, USA
5/5/2023 8:39am
DynoDan22 always bringing the facts👍. I would like to add something that I have found helps.
1. when all mounts are loosened, make sure all longer bolts along with swingarm bolt, move in/out easily before beginning torquing procedure. I have found on some of my KtM”s the rear of the engine drops down to put pressure on the swingarm bolt. If this occurs, I use a small block of wood to slightly raise the engine just enough for the bolt to slide in/out easily.
DynoDan22
5/5/2023 11:03am
If you really want to go to OCD levels, you can get steel shims from McMaster Carr in .10mm thickness and shim the engine mounts and swing arm interfaces so that you don’t add any residual stress when clamping up the fasteners. You wouldn’t believe the axial clearance between the engine cases/swing arm bearings/frame. When you tighten the swing arm nut, you can actually see the frame bend inward as everything clamps together. It amazes me how “sensitive” riders can tell a difference between after market engine mounts but they can’t feel the added stress when you deform the frame to clamp up the engine mounts themselves but I’m just one guy talking here. Lol
5/7/2023 3:26pm
DynoDan22 wrote:
The proper sequence for torquing the engine fasteners are: 1) swing arm axle nut (74 ft-lbs) 2) lower engine mount (44.5 ft-lbs) 3) forward engine mount...
Dan is this the general mounting process for all bikes?
DynoDan22
5/7/2023 4:50pm
Joe_Sprockets:  Yes. This is what I would recommend for all bikes.
YZed250
Costa Mesa, CA, USA
5/10/2023 1:21pm
The GG has soft valving, so you may need a revalve if the bolts are backing out after your loctite and torque sequence.
As soon as you reach the bottom of the travel or a square edge goes through the bike, there is a LOT of load that goes directly into the frame.
Post a reply to: Engine mount torque sequence on KTM/GasGas/Husq 450
