Countershaft Seal Question
Louie112
Austin, TX, USA
Hi Everyone,
Probably a stupid question but can you ride without a counter shaft seal? I know it’s not ideal but is it possible without issue or would I have a heavy oil leak or something else? Have a race on Saturday but can’t get the part in time.
Bike is an 02 YZ125.
thanks!
5/16/2024 12:11pm
no you cannot. You will lose oil immediately
Nairb#70
Ivoryton, CT, USA
5/16/2024 2:12pm Edited Date/Time 5/16/2024 2:14pm
On a 2 strk. you will lose transmission fluid, will damage gears, bearings and most likely clutch plates. On a 4 strk., you will lose motor oil and damage all of the above including main brgs., rod brgs. in addition to valve and camshaft components. You should have known!
5/16/2024 6:22pm
You are correct, it is a stupid question!
A YZ125 cannot run without a counter shaft seal, if you remove the seal, there will be no crankcase compression, it's unlikely the bike will even start, if it does start, there will be a significant amount of smoke out the exhaust, the spark plug will foul, and gearbox oil will be blown out the gearbox breather.
Have you rung all the dealers in your area?
Layton
Geneseo, IL, USA
5/17/2024 4:45am
You are correct, it is a stupid question! A YZ125 cannot run without a counter shaft seal, if you remove the seal, there will be no...
Actually you are wrong. The countershaft seal has nothing to do with crankcase pressure.
The engine will still run fine. The transmission however will be loosing oil quickly. Plus if it was ridden dirt would quickly damage the output shaft bearing and possibly others.
38special
5/17/2024 5:20am
Wow, very wrong info. You should brush up on your 2 stroke engine technology, especially given your user name.
5/17/2024 6:06am Edited Date/Time 5/17/2024 6:06am
Layton wrote:
Actually you are wrong. The countershaft seal has nothing to do with crankcase pressure.    The engine will still run fine. The transmission however will be...
@Layton, @38special I'll screen grab your comments before you edit them...
image-20240517223522-1
image-20240517230344-2
Engine tuners commonly use engine stuffers to decrease crankcase volume, increasing the crankcase compression ratio.
If you remove the countershaft seal, the total crankcase volume increases, because it then includes the clutch cavity and transmission cavity, reducing the crankcase compression ratio and crankcase pressure.
RGaede
Albuquerque, NM, USA
5/17/2024 6:39am
@Layton, @38special I'll screen grab your comments before you edit them... Engine tuners commonly use engine stuffers to decrease crankcase volume, increasing the crankcase compression...
The other guys are right.  On two strokes the crankcase is seperated from the clutch and transmission by the crank seals, no crankcase pressure in the transmission (they are even vented to atmosphere by a hose).
Back on topic, dont run the bike without a countershaft seal.  The transmission bearings will be shot best case,  worst case you'll need a new transmission because the gears will "weld" themselves to the shafts without lubrication.
5/17/2024 6:57am
RGaede wrote:
The other guys are right.  On two strokes the crankcase is seperated from the clutch and transmission by the crank seals, no crankcase pressure in the...
You didn't read my post, the OP was talking about running the bike with no countershaft seal, the crankcase, clutch cavity and transmission cavity are then connected.
Nairb#70
Ivoryton, CT, USA
5/17/2024 7:31am Edited Date/Time 5/17/2024 7:33am
You didn't read my post, the OP was talking about running the bike with no countershaft seal, the crankcase, clutch cavity and transmission cavity are then...
You need to take a lesson in BASIC 2 strk. engine principles and design. You've got it ass backwards. Change the word countershaft to crankshaft and you'll be close. Sort of.
RGaede
5/17/2024 7:37am
The countershaft seal is between the countershaft sprocket and the transmission bearings, nowhere near the crank.
seth505
SD, CA, USA
5/17/2024 7:46am
LOL, this thread has gotten funny. Not sure how you haven't grasped what people have written.  The countershaft seal is behind the front (countershaft) sprocket. It seals the inside of the countershaft from the outside elements. This shaft is part of the transmission, a separate cavity from the crank. It has zero to do with crankcase volume and luckily also has nothing to do with fuel and premix oil.
Nairb#70
Ivoryton, CT, USA
5/17/2024 7:53am
seth505 wrote:
LOL, this thread has gotten funny. Not sure how you haven't grasped what people have written.  The countershaft seal is behind the front (countershaft) sprocket. It...
Mind boggling!
38special
5/17/2024 5:44pm
LMAO.  Wow, he doubled down.  Laughing  Unbelievable.
Layton
Geneseo, IL, USA
5/17/2024 5:50pm
38special wrote:
LMAO.  Wow, he doubled down.    Unbelievable.
You beat me to it 😊
I was going to grab a screenshot of his post.
FGR01
5/18/2024 8:36am
We'll chalk all that up to Friday night posting possibly including a few drinks?  hahaa
Back to the OP......  did you already remove the old leaky seal???  Because you can just let the leaky one in and ride like that until the new parts come.   You've probably been riding it how long like that anyway?   A seal with a leak is better than no seal at all, for sure.   Just keep an eye on the trans oil level and maybe keep adding a little to keep it at the right level as it leaks a little.
5/18/2024 4:34pm
If you have the old seal take it to a local bearing supply house and they can get you something that works.
Louie112
Austin, TX, USA
5/20/2024 11:57am
Thanks for all the education guys! Except that one dude…😂 I figured it wasn’t possible to ride without it but thought I would ask.
I was actually told the countershaft seal was a little torn from the guy that put the motor back together but I pulled it out myself and looked at it and everything looked good. Filled it with oil and checked for leaks then started it and checked again. No leaks after riding either so I think it’s good to go but I have a fresh one coming just for insurance!
Post a reply to: Countershaft Seal Question
