Burning Oil On Cold Start 2022 MC450
AZIMM84
Logansport, IN, USA
2022 Gas Gas 450. I sucked some sand into the bike and killed the old rings.
Replaced piston, and had the head ported. Did a couple heat cycles and didn't have any issue. Now when the bike is cold it smokes and burns some oil until it heats up, once its hot it does not do it anymore... Cylinder was good deglazed , rings were set right. Valve seals looked good.... any ideas?
No air is coming out of the valve cover hose.
Factor E
So Cal, CA, USA
11/4/2024 7:34pm
Did you clock ring gap
AZIMM84
Logansport, IN, USA
11/4/2024 8:45pm
Yes
Factor E
So Cal, CA, USA
11/4/2024 10:29pm
Stem seals might not be good
Rider 5280
Denver Metro, CO, USA
11/6/2024 3:12pm
Curious - how bad does it smoke?
I've noticed that on my all stock 2022 KTM 450 SX-F with 40 hours, I see some smoke when I crack the throttle a few times when the bike is warming up. Bikes runs great, but I certainly don't like smoke of any kind.
AZIMM84
Logansport, IN, USA
11/6/2024 3:27pm
Rider 5280 wrote:
Curious - how bad does it smoke?I've noticed that on my all stock 2022 KTM 450 SX-F with 40 hours, I see some smoke when I...
more than a 2 stroke in 0* weather for about 4 mins then stops all together. Going to pull the head off this weekend
Factor E
So Cal, CA, USA
11/6/2024 8:03pm
Could be broken ring
11/7/2024 8:16am Edited Date/Time 11/7/2024 8:16am
Was the cylinder honed? If it sucked dirt in and took out the rings, just using scotch brite on the cylinder will not make it ready to use again, will need to be honed if it is within spec or replated if not. Have you done a leakdown test?
AZIMM84
Logansport, IN, USA
11/8/2024 7:44pm
Was not honed, going to buy another set of rings and hone it and change the valve seals......
mustard530
Long Beach, CA, USA
11/9/2024 11:36am
Did you use oem piston? Everytime I used a aftermarket piston on a Ktm 4 stroke I noticed it burned oil
AZIMM84
Logansport, IN, USA
11/9/2024 1:03pm
wossner
11/11/2024 6:33am
AZIMM84 wrote:
wossner
Did you check the ring gap? I just installed a wossner in a 21 mc450 and out of the box, the compression ring had 0 gap. Like absolutely no gap.
btroxler
Saltillo, MS, USA
11/11/2024 9:32am
Valve seals, as your bike sits its leaking oil onto top of piston and when you crank it up it burns the oil sitting on top of the piston. If it was rings it would never stop.
Post a reply to: Burning Oil On Cold Start 2022 MC450
