2 stroke top end issue
Johnnydirt
NY, NY, USA
I've done many a top end’s but this one is giving me issues.  2023 ktm 125sx ran great before I took it apart.   Put it back together ripped around the block bike runs great.  I get back to the garage and it’s weeping from two head bolt holes.  I tried giving it another little turn but it still weeps.  Took it all apart, O rings are not pinched, tried new copper washers but still leaks.  Anyone got an idea of what’s up?  Much appreciated.  IMG 4693.jpeg?VersionId=CsO5X3M5ubgE2cTNaQ
10/23/2024 5:19pm Edited Date/Time 10/23/2024 5:19pm
Install the head bolts in the holes without the head on and check they screw in far enough, you my need to run a tap down the holes to clean them out.
Johnnydirt
NY, NY, USA
10/24/2024 7:54am
I don’t think it’s a blind hole but I’ll give that a try thanks!
Factor E
So Cal, CA, USA
10/24/2024 8:23am
Surface head and re install
YZed250
Costa Mesa, CA, USA
10/24/2024 8:44am
Isn't that a 2-piece design head?
Johnnydirt
NY, NY, USA
10/24/2024 10:44am
Yes 2 piece head
SeTex
League City, TX, USA
10/24/2024 1:07pm
Take a metal straight edge & check the cylinder & head for high/low spots on the flat surface. Torquing to 13.3* ftlbs?
willbilly
Corpus Christi, TX, USA
10/24/2024 1:59pm
The copper head washers are supposed to be replaced because once crushed they will not seal. You can reuse them by annealing them.  Heat until cherry red and drop them into water. You can then use them repeatedly using this method.
Factor E
So Cal, CA, USA
10/24/2024 7:26pm Edited Date/Time 10/24/2024 7:29pm
Did you put new o ring on dome? Use sharpie to mark all flat surface before surfacing head and cylinder
Johnnydirt
NY, NY, USA
10/25/2024 5:12am
I did use new copper washers I had but I’ll annealing the old set so I have some extras.  Good idea with the sharpie.  I checked the cylinder cap on my kitchen counter and it looked good.
Post a reply to: 2 stroke top end issue
