CR200cc 2stroke engine?
Anthony1976
corpus christy, TX, USA
Hello Im wondering if anybody knows if Honda had released a CR200cc 2stroke thru the 1990's that never made it to the US?
Bearuno
4/15/2025 12:14am Edited Date/Time 4/15/2025 12:17am
Honda had the MTX200 from around '83  .
No 'CR' model.
There was an MTX200RW, from, supposedly,  83 / 98 . I think there was the actual model - the RW  - in the later years, and, Power Up Kits, so to speak.
Honda did the same sort of 'kit' for the CRM250s, both the 'normal' model, then the AR.
I think all of the above, were mainly Local / Asian market bikes, but, some were released in European / other markets.
All, were more of a 'Trail Bike'.
Just put it into your phone/ computer - you'll find them.
Anthony1976
4/15/2025 4:04am
Do you happen to know if the top end of the 98 will bolt on to a 98 125 bottomend?
Bearuno
4/15/2025 4:19am Edited Date/Time 4/15/2025 4:25am
I've no idea on that , sport.
I very, Very much doubt it - as far as I can recall, the 200 was based off the MTX125 Trail / Dual Sport  / Tiddler / Foo Foo 'Dirt Oriented' Commuter bike, that was in  quite a few markets - and Not related to the CR engines in any way.
Check out:
www.cmsnl.com/honda-mtx200rw-1985-f-england_model19514/
There's parts diagrams for the type of bike I'm referring to. You'll see it's a very different thing to a CR. Though, it had such a thing as a replaceable Head Insert / Dome.
Anthony1976
4/15/2025 4:35am Edited Date/Time 4/15/2025 4:38am
It doesn't look like a real performer, doesnt appear to have a powervalve. It was made till 1998R 1.jpeg?VersionId=ZpLdP1uscxr 1PZ1Y35RrghzAkyA9R4
4/15/2025 5:04am Edited Date/Time 4/15/2025 5:04am
It puts out a whopping 27 hp, the ATAC is Honda's early version of a power valve, there is a passage...
image 1520.png?VersionId=N9NI9uQS484C0i8DM1TrX6Rq
that connects the exhaust port to the ATAC chamber, with a valve in between, opening and closing the valve changes the exhaust pipes volume.
Bearuno
4/15/2025 5:13am Edited Date/Time 4/15/2025 5:28am
As I wrote - it's a Trail Bike. As you deduced, it's not a 'performer' as such.
It's got an ATAC  ( 'HERPES' is what Honda called it on several models - at least until they realized what that meant in many places of the Globe 😁 ) set up - whatever it is - there's a flapper at the exhaust port, so, perhaps it was more than just the variable volume header section that the CRs had, intitially.
I think the closest to a 'CR" engine  that Honda did that was out at the same time, was the MR175 and 250s, in the 70s.
Though, I think the pre 'AR" 250 CRM engines could be fitted with CR parts of that era. Though, I think say, the head of a CR could be fitted to the AR.
Anthony1976
4/15/2025 5:20am
Ya, that valve probably kills the engine as far as max hp. Theres said to be another version that makes 34hp, probably in a ported raised compression form it also says it was a competition motor but you can't trust what the net says 60 percent of the time
Anthony1976
4/15/2025 5:22am
Screenshot 20250414-225823 0.png?VersionId=aXOhLxW.A7mrrsDGQHrQCVAWS
I'll probably just mess with this thing
GCrites
GROVEPORT, OH, USA
4/16/2025 6:42pm
With the trikes there was a 200 class. It started out as something for the 200X four-strokes but the rules didn't specify that they had to have a 4-stroke engine so people started building sleeved-down 250Rs. The air-cooled 250R engine was based somewhat off of the '81 CR250 engine while the liquid-cooled ones were based off of the '85 CR250 engine. No power valves or ATAC and they had counterbalancers. With the engine work performed the 200cc motors were able to meet or exceed stock 250R power numbers.
Nairb#70
Ivoryton, CT, USA
4/17/2025 7:54am
Lots of unique markets outside the U.S.
Anthony1976
4/17/2025 4:00pm
A sleeved down 2002 cr250 is.gonna be too big for a 125frame.
I need to find out if there's powervalve problems with the susuki is making 22ftlbs of tq stock with a 30mm carb.
I found this healthy 150psi bike with a 33mm carb. But its not that rare anymore
https://youtu.be/d93hQ8YO4Zc?si=7zUA25AbUeTUYE0N
The newer yz200 he got rid of it because it was slow because his bore was tapered and he tried to clearance the piston himself and he probably set up a cast piston with forged clearance OIP 0
post-171984-0-66745100-1405642916
coreyyt
Los Angeles, CA, USA
4/19/2025 8:18am
Yes , Honda released the Cr200 in some markets but wasn’t released in the USA , it’s usually popular in the Europe and Asia
Anthony1976
5/11/2025 12:08pm
That Suzuki 200 is making 22ft lbs of tq stock with a 30mm carb. That's like 4ft lbs more than the current 250 4stroke
Post a reply to: CR200cc 2stroke engine?
