Ruskin, FL, USA
7/6/2019 3:20am
Even though I use a torque wrench I think KTMs torque specs are a bit high. I stripped the threaded collar that goes in the bottom of the shock that is the nut for the lower shock bolt. I tried backing the bolt off then giving it a few good whacks but it didn’t look like it budged.
Anyone had to replace theirs and how did they get it out?
Are the threads stripped or is the insert spinning?
I put a heli-coil on another (if threads are stripped).
You can call factory connection and see if they can replace it or sell you the insert if you can press it out/in yourself.
Just wondering the best way to get the old one out. I backed the bolt out a half inch then gave it a few good hits with a hammer on a socket and extension.... didn’t budge.
Post a reply to: Stripped lower shock nut insert
