Snapping Spoke
I have a 2020 YZF450 and the same spoke has snapped 3 times, (the one next to the rim lock) on the front wheel. Each time I replace it with a genuine spoke and nipple and do not overtighten it, can't see any issues with the rim lock or rim.
Anyone had this issue, any ideals what could cause it?
Thanks.
kb228
Mansfield, OH, USA
8/23/2021 6:45am
Id make sure the wheels radial and axial runout is what its supposed to be and see if the wheel lock is tweaking the rim just a little too much
willbilly
Corpus Christi, TX, USA
8/23/2021 12:26pm Edited Date/Time 8/23/2021 12:26pm
KB covered it. Only thing I can add is that the spokes all have to work together. Are all the other spokes tightened properly? If the rim lock spoke is loose you shouldn’t just tighten that one. There are tutorials on the internets. Basically get a starting point like the rim lock. Tighten that spoke, skip two, tighten third. Continue around the wheel tightening no more than a quarter turn for each spoke. It should take three revolutions. Repeat if some still need tightening. That procedure will keep the wheel true and all the spokes sharing the load. Good luck.
Hammer 663s
None, AE, USA
8/23/2021 2:21pm
Where does it snap? If at the hub, make sure there's no bur or anything stressing the spoke, and that the hole isn't wallowed out. Are you putting a little oil on the friction points at hub and rim, and anti-seize on the threads?
spimx
Port Isabel, TX, USA
8/25/2021 5:43pm
I would put liquid wrench on each spoke and buy a spoke torque wrench. As well as check the wheel for round. Harbor freight has a stand for balancing a motorcycle wheel that would be very helpful.
8/26/2021 5:34am
kb228 wrote:
Id make sure the wheels radial and axial runout is what its supposed to be and see if the wheel lock is tweaking the rim just...
Thanks dude, the wheel does seem a bit out of true so I will look into that some more.
8/26/2021 5:35am
willbilly wrote:
KB covered it. Only thing I can add is that the spokes all have to work together. Are all the other spokes tightened properly? If the...
Thanks dude, I could be going wrong here as I just tightened them in order, watching some videos online seems like I'm doing it the wrong way each time.
8/26/2021 5:35am
Where does it snap? If at the hub, make sure there's no bur or anything stressing the spoke, and that the hole isn't wallowed out. Are...
Snaps half way inside the nipple each time, leaving some thread stuck in the nipple and a little bit on the spoke it's self.
Post a reply to: Snapping Spoke
