STIC Metering block Jetting
Yotam
IL
Edited Date/Time 10/20/2019 9:27am
Hi all, i have CR125 2007 with big bore kit (144cc)
I had PWK 36 short body type on it and i decided to purchase the STIC metering block
My initial jetting (with the pwk blok) was; 165 main, NOZH 2nd clip, 48 pilot
The bike ran great on sea level with lots off low end crisp power
i have just installed the STIC metering block it is .114 tube with 180main, NOZH 2nd clip and 48 pilot.
The bike pulls hard and very good from mid to top but it’s running way too rich down low
Now, i can start try to jet it leaner and try to dile it in but i am afraid to ruin my motor
Right now i am preparing my bike for enduro with lots of slow tight technical terrain so i want to solve it quick or I will have to go back to the stock carb and loose the mild to top hit that the STIC gives
Any one with experience in it?
Any one have George Bosewell email adress?
Thanks
BR8ES
Bennett, CO, USA
9/8/2018 1:19pm
How many turns out on the air screw?
Yotam
IL
9/8/2018 1:37pm
Thanks for the reply, just sent him an email.
I am not sure about the air screw, i simply adjusted the it untill the bike was idling well
BR8ES
Bennett, CO, USA
9/8/2018 1:46pm
Air screw should be around 3 or so from fully closed, maybe even 3.5
Yotam
IL
9/8/2018 1:51pm
Got you,, i didn’t touched my air screw at all
Just installed the stic and started riding
Even cold start is pain in the ass...
I hope that this is the problem
BR8ES
Bennett, CO, USA
9/8/2018 2:19pm
Yotam wrote:
Got you,, i didn’t touched my air screw at all Just installed the stic and started riding Even cold start is pain in the ass... I...
Give it a shot, bet it will be the ticket as the rest of it sounds good.
Hcallz5
9/8/2018 7:36pm
I'd suggest ordering a NECJ needle. They make such a clean strong power curve. I run one in my ktm 200 xc and it's fantastic.
BR8ES
Bennett, CO, USA
9/8/2018 9:10pm
N3EJ Yamaha needle is the go to needle, can't think of anybody running a NECJ needle with the STIC.
Tomok
Epping, NH, USA
9/9/2018 7:13pm
With the STIC, George recommends running a much larger pilot jet than without the STIC. Are you sure that it is not running lean down low?
BR8ES
Bennett, CO, USA
9/9/2018 8:58pm
A few have been running a 48... if it runs good then the AS tweak hopefully does it.
CSAR FE
Tucson, AZ, USA
9/10/2018 11:38am
You need a needle with a thicker straight section diameter, and your air screw needs to be between 3 and 4 turns out.
BR8ES
Bennett, CO, USA
9/10/2018 1:53pm
N3EJ Yamaha needle works really well .
cslacker
Glendale, AZ, USA
9/10/2018 3:44pm
I'm running an NECW in my 2003 cr250 with the STIC. Works well. Considering trying the N3EJ or N3EW.
CSAR FE
Tucson, AZ, USA
9/10/2018 4:00pm
I can second this. I’ve been using the N3EJ needle in my 300 and it has worked the best out of the myriad needles I have tried.
Yotam
IL
9/11/2018 12:00am
Seems like opening the air screw to 3.5 turns did very good job, the bike stopped “chocking” on low rpm but it is still feels like it’s little too rich, i will have to wait for the right needle I guess N3EJ is the first one to try
BR8ES
Bennett, CO, USA
9/11/2018 5:14am
Try a 52 pilot
erik_94COBRA
Houston-ish, TX, USA
9/11/2018 5:17am
Running a N3EJ, 52 pilot, A/S ~3.5, 198 main on my 2014 KTM 150SX. Runs pretty good. I am rich at the moment but will lean out next outing.
Tried the NECJ and didn't run as well with it.
Yotam
IL
9/11/2018 5:59am
BR8ES wrote:
Try a 52 pilot
52 pilot will not be richer than what i have now?
Yotam
IL
9/11/2018 6:01am
Running a N3EJ, 52 pilot, A/S ~3.5, 198 main on my 2014 KTM 150SX. Runs pretty good. I am rich at the moment but will lean...
Are you running 38mm carb?
Because the jetting supposed to be different between the 2 (i have 36)
erik_94COBRA
9/11/2018 6:12am
Yes I am running the 38mm.
Do you have any other needles?
BR8ES
Bennett, CO, USA
9/11/2018 7:02am Edited Date/Time 9/11/2018 7:09am
BR8ES wrote:
Try a 52 pilot
It is a bigger jet, but this system needs it. Try the next size up. I have a 52 for my 125. Jets differently than typical. The needle will make it run better overall. What slide?
What did George say?
Yotam
IL
9/11/2018 7:39am
I have NOZG & NOZF, it will take time until I get the needles i need
Where i live dealers are not holding stocks like that
Yotam
IL
9/11/2018 7:41am
BR8ES wrote:
Try a 52 pilot
BR8ES wrote:
It is a bigger jet, but this system needs it. Try the next size up. I have a 52 for my 125. Jets differently than typical...
George didn’t reply my email yet
Waiting for him to answer
I will order the 52 pilot and try it
BR8ES
Bennett, CO, USA
9/11/2018 8:32am
I sent George an email too, maybe he missed yours. Asked the same questions you are, etc. He should respond.
Yotam
IL
9/11/2018 8:35am
Thanks mate!!!
There’s a holiday here, Tomorrow our Yamaha dealer will be available and i will purchase a 52 pilot and N3EJ neddle
STIC
Eagle River, WI, USA
9/11/2018 8:56am
Yotam my apology I seem to have lost your email contact; I initially responded by telling you I would get with you on Sunday U.S. was at a friend's wedding. CSAR and others are very intelligent and well versed, take their advice. I will respond as soon as I have your email. George
STIC
9/11/2018 9:24am
The STIC metering block features:
Voice of Robert: “I have tested the STIC metering block; “Here is my review of the STIC metering block:” “The invention of the STIC metering block and methodology may be one of the greatest examples of a superior engineering design that controls air-fuel elemental molecular vaporization and the rate of the air-fuel-vapor flow rate into the engine based on the STIC’s ability to sense changing engine dynamics; driver, and landscape demand changes including changes in temperature and altitude.
I have carefully tested and reviewed the STIC block and STIC tube. This includes its claims and various features. I have talked with the inventor and here are some of the STIC features that I agree; they are true as claimed after my review: (1): The STIC system appears to more effectively utilize the available oxygen no matter where it is in terms of altitude and temperature. (2): The STIC auto-selects the prevailing higher pressure; choosing from atmospheric and the engines fluctuating intake, combustion, and exhaust pressures. This feature allows the carburetor to create a higher differential pressure drop [vacuum]; thus causing instant air/fuel vaporization independent of engine suction. (3): The STIC has an acceleration system that auto-loads; thus having instant acceleration from all positions including low rpms. Due to the fact that the STIC system is able to sense engine intake demand and pressures; it has the ability to have a broad jetting range and it appears to know which engine it is on thus requiring very little changes in jetting. This is confirmed by comparing CSAR’s 300 with TOKYO: Mark’s (Japan) 250 utilizing similar jetting verses Phil’s 300; they have identical jetting as CSAR’s jetting in New Mexico at 5200 feet. (4): The STIC has a power system that does not need power wings, power jets or small carburetors. The pilot jet is now part of the STIC power system that blends the pilot jet fuel and its related air circuits into the jet tube outlet; this is one of the reasons the front air screw and the larger pilot jet is part of the equation. (5): the inventor tells me the optimum should use a #6 slide; and reports most applications will want to use the 38mm carburetor as you no longer need the smaller carburetor to cause it to trigger. The inventor also reports there will be a new air screw and idle speed screw coming soon, and there will be new STIC needles on the horizon that will come with the STIC metering system.” Robert Engineering.
BR8ES
Bennett, CO, USA
9/11/2018 1:41pm Edited Date/Time 9/11/2018 1:45pm
Yotam, give George another email, he is expecting you.
stic@frontier.com
Yotam
IL
9/11/2018 2:22pm
stic@frontier.com
Clear, done.
Yotam
IL
9/23/2018 8:29am
Does NECJ could work better than NOZH i have now?
I have ordered 38mm PWK with the right set up but it will take 3 weeks before i will get it (crazy Israeli customs cintrol...)
But i found the NECJ in my tool box
Post a reply to: STIC Metering block Jetting
