San Diego, CA, USA
8/14/2020 2:49am
I just rebuilt the forks on my 2013 KTM 250 sx-f with new WP seals and bushings and new Racetech fork springs. After putting the forks together and mounting them on the bike, there was a grinding noise coming from the forks. I took one off(they both sound like this) and compressed it by hand and this is what it sounded like.
I took the forks apart and the sound wasn't coming from the fork tube bushings, so then I thought I might have messed up the springs or had gotten the wrong ones. When I took it out, I noticed the Racetech springs had a rough surface to them. When I checked the stock spring, it's polished smooth.
Racetech
Stock KTM Spring
I searched around and found a post on TT that said " I was told that the RT springs would be a little louder than the OEM due to their shot peening. It makes a rougher surface initially on the spring, which will wear down with time and become quieter."
Does that sound right? The front end of my bike sounds like a rusted pogo stick. And the "wear down with time" sounds like all that worn material is going to end up in my fork oil.
Does this sound right to anyone?
Racetech
Stock KTM Spring
race tech springs. I called race tech and they told
Me it was ok!!? It drives me nuts because the Oem
Springs made no noise. When they touch the
Inside of the fork tubes it’s a scraping noise and
Is very disconcerting. The forks function great and
They said it is ok....
If I sent my forks to a tuner and got them back sounding like this, I would have thought they screwed up. I still can't believe Racetech sells the springs like this, they must get complaints about this.
Sells springs like what? There’s nothing wrong with them. Either ride the bike and let them smooth out, or pull them out and send them back. I’d just let it ride man. It’s really not a big deal at all.
I’ve got some springs & gold valves on the way, I’ll pay attention to that,
Did you ever find out what the noise was where it was coming from??
CSAR FE is correct. Race Tech springs are noisier than stock springs until they are polished by rubbing on the fork tube @ about 10-20 hours.
Post a reply to: New Racetech fork springs making grinding noise.
