Kx450f backfire after rebuild
lambo609
Mays Landing, NJ, USA
2017 kx450f Last weekend my bike died . Piston cracked down the middle . Replaced the piston today . Cylinder appeared to be good . Could still see cross hatching and there were no imperfections I could see or feel . After putting it all back together I went to start it and it fired right up two kicks no problem . It idkes and won’t die when I rev it but it backfires repeatedly and sounds terrible .
I’ve rebuilt more then a couple top ends . First time doing the kx450 but rebuilt the kx250f several times . Just looking for some insight . Fairly certain the timings good and I’m pretty sure it would not start right up if timing was off
Any suggestions would be much appreciated
Paw Paw 271
Benton, LA, USA
11/4/2021 7:09am
Did you replace the cam chain?
Have you check the fuel filter and pump for dirt?
Have you cleaned the injector?
PawPaw
kb228
Mansfield, OH, USA
11/4/2021 7:58am
Id look into an exhaust leak. Replace the copper gasket and check the connection to the muffler. It wont run if its 1 tooth off and as long as you didnt mix up your shims it should run the same as before.
Did you bump the tps by accident during disassembly?
lambo609
11/4/2021 3:59pm
kb228 wrote:
Id look into an exhaust leak. Replace the copper gasket and check the connection to the muffler. It wont run if its 1 tooth off and...
I was honestly thinking tps might be the issue. I don’t know if I knocked it or not to be honest . I know there pretty sensitive but I’m not to sure how to even troubleshoot one .
PK27RACING
Louisville, KY, USA
11/5/2021 6:18pm
Exhaust leak or valves. Do a leakdown test.
hubbardmx50
Rancho Cucamonga, CA, USA
11/6/2021 10:34am
Made sure all connectors are plugged in? MAP sensor, air temp, water temp?
Grovesy98
11/6/2021 4:28pm
I had a 18 KXF450 skip a tooth on the timing and it still ran, just popped and was a bit erratic. Turned out the cam chain was toast after only 30hrs
mshea397
Prior Lake, MN, USA
11/6/2021 6:36pm
check the cam timing. i was a tooth off on my 2013 and it ran how you described.
Leeham
Rochester, WA, USA
11/8/2021 1:13pm
Check timing and clearances. Make sure tensioner is working. Then after that maybe do leakdown and check connections.
Post a reply to: Kx450f backfire after rebuild
