Hey guys. So I replaced the cylinder and piston in my 2012 KX250f and when I went to start it up, the engine would fire and run for 10 seconds or less before stopping. Does anyone have any ideas on what might cause this? My first thought is the timing might be slightly off, but I thought I would ask around and do some research before I go crazy looking for the problem.
Have you checked the fuel pump and filter?
Have you cleaned the injector?
Have you checked to see that all electrical connections are plugged it and clean?
I did check the injectors and electrical connections, but did not check the fuel pump or filter so I will give those a look along with another once over of the rest of the fuel system.
The tip over sensor was removed so I will double check that as well.
Thanks for the places to start looking.
Free shipping: VITALMX
Since we’re on the subject...
I’ve got a 2014 KX250F that’s been apart for a year and getting ready to be built this winter. The fuel injectors have been stored in plastic baggies, but what’s the process of cleaning them?
Spraying them down with a solvent like carb cleaner? I believe I’ve seen a special tool that flushes them in automotive applications, but i don’t know if that applies with MX bikes. Thanks.
Post a reply to: KX250F Engine Running Issue
