KTM shock change.
lappedrider
Tooele, UT US
Edited Date/Time 6/10/2019 11:58am
Getting ready to replace the shock in my 2018 350. Is it going to be as big of a pain in the ass as it looks like or is there a trick? Someone told me it’s easiest to remove the swing arm....🤷🏻‍♂️
BR8ES
Bennett, CO US
6/8/2019 3:30pm
really not that hard... can remove it thru the bottom or take the subframe off and have even more room. I usually just remove the seat/subframe.
lappedrider
Tooele, UT US
6/8/2019 3:31pm
Thanks man. That’s what I assumed.
T-Fish
Sparta, WI US
6/8/2019 5:15pm
I remove the linkage, exhaust, and slip it out between the air box and swing arm.
CarlinoJoeVideo
Portland/Los Angeles, CA US
6/8/2019 7:16pm
I do linkage and muffler.
I saw the KTM R&D remove the swingarm pivot.
BR8ES
Bennett, CO US
6/8/2019 10:58pm
Different strokes fellas, I don't care for that method or fumbling around pulling out thru the bottom. Couple extra bolts and the sub comes off with the exhaust and plenty of room.
aaron63
6/10/2019 2:37am
Remove Chain, Undo linkage arm from triangle, undo shock bolt from triangle, undo 2 x 8mm bolts from rear brake master cylinder, undo swingarm pivot bolt, pull swingarm back, undo top shock bolt, shock will pull fall right out the bottom of the bike. Easiest way by far.
aees
6/10/2019 11:58am
Easiest is to just drop the front linkage bolt from frame, remove silencer and remove the shock. If needed, just loosen up the pipe bolt that sits in the engine mount to get some more room.
T-Fish
Sparta, WI US
6/10/2019 1:15pm
By exhaust, I meant silencer.
Post a reply to: KTM shock change.
