Temecula, CA
I have a '22 KTM 250F
The manual states to press the TC and Map buttons simultaneously while the bike is in neutral and idling, and then the MIL will flash rapidly to show it's activated.
I tried this dozens of times with no luck. When I push both buttons simultaneously, the TC and Map lights will flash twice, and the MIL will flash once - that's it - no rapid flashing whatsoever. Am I interpreting this wrong? I thought the MIL should flash rapidly, and stay flashing until launch control is off
Note - The TC and Map switches both work fine - I can turn TC on or off, and change maps no problem.
Free shipping: VITALMX
Anyway it turns out the gear position sensor wasn’t communicating with the CPU. They re-flashed the CPU and now launch control is working as it should
Post a reply to: KTM Launch Control Help
