Fuel ratio
dcummins69
Medford, OR, USA
I recently decided to change my fuel ratio on my RM 250 to 50 : from 38 :1… My first time out I noticed it had a bog from bottom end and it had a weird rev with the idol… Not to mention surging while going down a road at a steady speed… Is this an indication that I need to change my jetting If I’m going to run this fuel ratio? BTW I use redline synthetic oil .
ktm-5
Ravenna, MI, USA
11/28/2017 5:29pm
It is probably running rich now that u have taken oil away and added more fuel so u would need a smaller jet. With the bog on bottom u could try adjusting your air screw out some depending on how far it is already out or u will need a smaller pilot jet. Why have u decided to change oil mixture?
BobPA
11/28/2017 8:18pm
ktm-5 wrote:
It is probably running rich now that u have taken oil away and added more fuel so u would need a smaller jet. With the bog...
Hanging idle and surging are lean conditions. A small change in oil ratio will not have enough of an affect to cause such a drastic problem. Sounds like a left side crank seal went away, or you have some type of air leak.
ktm-5
Ravenna, MI, USA
11/28/2017 8:29pm
BobPA wrote:
Hanging idle and surging are lean conditions. A small change in oil ratio will not have enough of an affect to cause such a drastic problem...
Your right I must be missing where he said a hanging idel. I didn't think the oil ratio would make much of a difference either but depending on how it was jetted b4 it could as if it was already on the fat side maybe the more gas would have affected it?? But definitely a good idea to check for air leaks
dcummins69
Medford, OR, USA
11/28/2017 8:30pm
I tried spraying carb clean around flywheel and no change in idle... not sure if it could still be leaky seal
dirtmike86
Grand Terrace, CA, USA
11/28/2017 9:34pm Edited Date/Time 11/28/2017 10:08pm
Just go back to the old mixture and see if it still does it. Then you know thats the culprit and you can jet it according to your new ratio. Not that its much help but i switched from pump to VP T2 on my RM250 and had to lean the jetting out. Idled higher on pump and had slight detonation at high rpm.
dcummins69
Medford, OR, USA
11/29/2017 5:44am
OK… Long story short my bike was running fine at a track a couple hundred miles away had a little bit higher elevation and when I came in it started surging with a high idle and I didn’t think nothing of it I thought maybe it could’ve been the elevation or it was running hot something along those lines… I’ve been meaning to change my fuel ratio because I knew I could run it a little leaner with synthetic oil and it seem to smoke quite a bit at the ratio I was using… I change the ratio and that first ride out After track day I noticed it started running real temperamental and had an excessive surge at a high idle also when I would go down the road at a steady speed it would start lunging and surging so I kind of have two different issues going on here crank seal seeming the most obvious but I did pull the flywheel cover off and squirt carb clean around it and there was no change in the idle at that point ...I also tried spraying the boot, going to have to go back to old ratio and eliminate that possibility for now, still I’m skeptical it’s the ratio.
dirtmike86
11/29/2017 8:09am Edited Date/Time 11/29/2017 8:13am
There is also the right side crank seal that can go bad.when mine went it didnt have those symptoms. It just leaked tons of oil and wouldnt idle. Wouldnt hurt to check the reeds.
11/29/2017 8:35am
Spray some starting ether around the reed cage. Sometimes they don’t seal well or start sucking air.
If you use carb or brake clean, wipe it off or it’ll eat at any rubber.
dcummins69
Medford, OR, USA
12/4/2017 4:31pm
Ok, I did notice oil at the crank seal but !! Not only was there no change in idle with carb clean I replaced the seal and it’s doing the same thing.
Any ideas?
dcummins69
Medford, OR, USA
12/4/2017 4:32pm
Btw... I did spray either all around reed cage and boot as well .
ktm-5
Ravenna, MI, USA
12/4/2017 5:44pm Edited Date/Time 12/4/2017 5:45pm
Changing your oil ratio does not make your bike run leaner. The amount of fuel decides whether you are rich or lean. maybe u are sucking air from your exhaust
12/4/2017 6:13pm
ktm-5 wrote:
Changing your oil ratio does not make your bike run leaner. The amount of fuel decides whether you are rich or lean. maybe u are sucking...
Actually the oil to fuel ratio does affect the fuel to air ratio, albeit not by a significant margin. The jets only pass a finite amount of fluid, so when there's more oil, there is less fuel which makes the air fuel ratio leaner.
More premix oil makes the air to fuel ratio leaner.
That said, unless you're jetted so perfectly Mike Gosselaar would be impressed it's unlikely going from 50:1 to 38:1 will make a noticeable difference.
Many years ago I had an issue with RedLine 2 stroke oil separating. Don't know if that's the case here, but might be worth looking into.
dcummins69
Medford, OR, USA
12/4/2017 6:16pm
Yes I have realized this, this went from the question of the mixture to the crank seal which I thought was it from what I researched, I’m going to tear the carb down to eliminate that avenue, also have to look at the exhaust, I know it drips a lot of unburned oil out of where it meets the cylinder??
ktm-5
Ravenna, MI, USA
12/4/2017 6:34pm
Actually the oil to fuel ratio does affect the fuel to air ratio, albeit not by a significant margin. The jets only pass a finite amount...
Umm I think in a way we are saying the same thing?? I was saying if a guy was adding less oil to lean out their bike that it doesn't work that way as much as they want, like u said it doesn't affect it as much. If someone wants to lean their bike out because it's running rich changing the oil ratio is not going to do it and it's not running rich because of oil it's rich because of too much fuel. So I'm not sure what I said that u misunderstood but we are pretty much saying the same thing....lol
dcummins69
Medford, OR, USA
12/5/2017 4:26pm
It was dirt in the carb, pulled it apart blew it out and it purrs like a kitten again !!! My crank seal was leaking anyway and I was able to check my crank bearings in the meantime , thanks everyone .
ktm-5
Ravenna, MI, USA
12/5/2017 4:28pm
Glad to hear u got it figured out
Post a reply to: Fuel ratio
