Just finished off building my CR125, sounds to me like its detonating ( rattling cans is the best description). I can't decide if it's just really crisp 2T sound.....lol.... It could be the older gas I chucked in to start it.... So I'll be starting there....
I'm curious as to what other signs there are to tell if I have detonation issues...
Piston condition on the edges, by observation.
Measured squish is also important.
If as stated you used old fuel, then it would by nature cause some noise and could be justify your concerns.
Dump the old fuel and put in a fresh mix using at least 93 oct and see if it sounds better.
What would you look for with the plug colour??
What would should the squish be?
On the piston you can look for pitting on the piston edges next to the cylinder walls. If these pits are there you have pre-ignition or detonation that in most cases is caused by the squish being too tight or the use of low octane fuel.
You should be able to see this through the exhaust port with the piston at the bottom of the stroke and this cam be done by just removing the exhaust pipe.
If all above looks good then, just make sure the jetting is good and you are using good fresh fuel and you should be good to go.
To check the squish you need to remove the head and will use soft large solder. The exact squish gap for your engine should show up in the service manual. You can also look up the book "Two stroke tuning guide" for these figures and how to calculate them. If the squish is too tight you don't get the needed fresh fuel cooling to the edges of the piston and thus generate excess heat that will cause the ring to stick in the ring groves of the piston and or the piston edge to get so hot that it will deform on the ring and cause it to stick and then you have no compression. Conversly, if the squish is too big then you don't get a full burn of the fuel.
I'll get onto the squish ASAP and get fresh 98 octane.
98 is the standard here for most bikes, for some reason the fuel ratings and quality vary from that in the US... prett much anyone here will use 98 as the baseline.
It's a 2006 cr125
Post a reply to: Detonation-identifying-causes?
