CR250 Crank Journal
Bent206
Coventry, RI, USA
Edited Date/Time 3/5/2020 4:42am
I’ve never had this issue with a crank before. I’m able to push the crank bearing on with my hand.
Is there anyway to fix this or is the crank half ruined?
This is out of a ‘79 CR250. So it has some age to it.
JMCR250
Chesterfield, MO, USA
3/4/2020 6:27pm
Send it to CrankWorks in AZ. They just repaired a similar issue with an '82 CR250 crank I sent them. While it was there I also had them replace the big end bearing and install a new rod. Good to go now.
Momus
CD
3/4/2020 8:28pm
Don't get too concerned if it is a sliding fit, with no play. Use some red loctite and it will be fine.
DynoDan22
Victorville, CA, USA
3/4/2020 8:44pm
Journal can be fixed as mentioned above by sending it to be hard welded and ground back down for the press fit to the main bearing. It differs per bike but usually only one side is a press fit (left side for Honda, Yamaha and Suzuki) while Kawi did have a press fit on both journals. I believe that if the crank had excessive runout it wears the journal over time but sometimes, it could just be a bad crank from the factory.
Momus
CD
3/5/2020 2:31am
Drive side was often slip fit and tightened by the primary gear nut to stop the inner race rotating against the journal but allow simpler assembly.
Tight fit on the magneto side usually.
Bent206
Coventry, RI, USA
3/5/2020 4:42am
Thanks for the replies.
Unfortunately, mine is loose on the ignition side. I'll contact CrankWorks and see what they can do.
DynoDan22
3/5/2020 7:18am
A slip fit on the magneto side will eventually develop radial play (up and down play).
Post a reply to: CR250 Crank Journal
