SE
7/12/2019 7:04am
Have had the bike for 4,5 years. Ktm 65. second son racing it right now.
The carb have never ever flooded on the stand.
Washed the bike, new filter, start the bike... and it´s just pooring out.
Cleaned it but could find anything.
needle good no sign of wear
checked the needle seat and the oring. tested with compressed air in fuel line. OK
adjusted the "tab" so it closees the needle early, 3 times and now its carb is not leaking.
Can it change during the ride?? or have I a ghost that play me a trick?
Help !
Help !
Nope turned off after ride and turned on after washing.
Tested the oring, with air test and without the bowl and fuel line connected no leak
If the tab was bent the tab by riding, I did not notice any leak then loading the bike.
So the tab pends then I lay it down and washing it
The pin that goes through on the floating thing was not missallinged then I took i apart the first time.
Free shipping: VITALMX
I changed everything in the carb but the float needle seat...
Post a reply to: Carb float height Problems, change during ride ?
