Looks like valve cover comes off no problem. not sure if I can slide the head off off the bolts and have it clear the frame tho. Trying to time this with getting frame pc'd so hopefully I can just do the top end now and pull motor later when its due again and do the frame at the same time.
thanks
thanks
Post a reply to: Can you do a 250sxf top end without removing engine from frame?
