CR250R Engine Rebuild Advice
Does anyone have a complete parts list for a top and bottom end rebuild on a 2003 CR250R? I am worried I will miss some bearings or seals in the bottom end really.
I was going to contact Service Honda, but they have closed up shop it looks like.
Thanks!
Paw Paw 271
Benton, LA US
1/17/2017 8:44am
Go to one of the OEM parts suppliers online and do a search for your bike parts.
adam8781
1/17/2017 9:06am
mjr119 wrote:
Does anyone have a complete parts list for a top and bottom end rebuild on a 2003 CR250R? I am worried I will miss some bearings...
Thanks!
2005-07 cr250 crank (02-04 crank is a horrible design)
pro x piston kit (made in oem japan factory)
oem 05-07 base gasket (thinner than 02-04 helps fix port timing)
pro x crank bearing
anything pro x is as good as buying oem.
I would just go on rmatv and buy everything these
ledger
TN US
1/17/2017 9:57am
I'm not sure if the 03 will benefit from having the cylinder base or head shaved, but there is a ton of threads that involve the 05-07 CR 250's. Eric Gorr seems to have a lot of info on 02-07's, he might be worth contacting and he's easy to get along with. Just an idea.
1/17/2017 10:18am
Right, I know how to check the parts fiche and all. I just don't want to miss anything.
I was hoping someone might have a list already compiled, such as Service Honda. Not asking someone to tell me which parts to buy. Just hoping to save myself a little time and effort.
Paducah, KY US
1/17/2017 6:40pm
Pretty sure I have everything you need in my shop right now for my 03. Do you need a crank also?
I would be happy to box it up and ship it to you.
1/18/2017 4:10am
809 wrote:
Pretty sure I have everything you need in my shop right now for my 03. Do you need a crank also? I would be happy to...
Yes I do. Can you shoot me a text? 3362391438 thanks!
Monk
1/21/2017 6:19pm
I would look into the Wrench Rabbit deal... Apparently it's EVERYTHING needed when doing a motor job...
1/21/2017 6:46pm
X2, check them out
MotoMo165
TX US
6/16/2019 6:01pm
Hey boys I’m about to bite the nail and order a new crank for my 03 cr250. Hot rod doesn’t make a kit for my bike. Will the 05-07 hot rod kit fit the bike?
One option is the wrench rabbit kit for 530. Anyone have experience with that kit?
kb228
Mansfield, OH US
6/16/2019 6:07pm
MotoMo165 wrote:
Hey boys I’m about to bite the nail and order a new crank for my 03 cr250. Hot rod doesn’t make a kit for my bike...
Why cant you send your OEM one to get rebuilt? That is better than either of those options by a mile
MotoMo165
TX US
6/16/2019 6:40pm
better chance I’m buying a new oem crank before I go that route. Only issue is there is a wait and my buddy doing the work leaves town soon.
MotoMo165
TX US
6/16/2019 7:52pm
Anyone have experience with the wrench rabbits bottom end kit? Or know if any other year cranks/parts will fit in an 03? Hot rod doesn’t Make a kit for the 03 cr250s (from what i am seeing from the bto sports page.
If I were to buy parts separate, I’d be buying crank, main bearings and seals and a gasket kit. Am I missing anything? Thanks for any help, I won’t have time to post tomorrow until late and would like to order the parts as soon as possible
r18b
NL
6/17/2019 1:47am
Don't understand why people go the hot rod route or any other shit route while you can get the 05-07 oem crank. Same as for the piston. The oem piston or the prox piston is such a crap on a cr.
MotoMo165
TX US
6/17/2019 8:45am
r18b wrote:
Don't understand why people go the hot rod route or any other shit route while you can get the 05-07 oem crank. Same as for the...
Sooo the 05-07 oem crank fits in the 03?
kb228
Mansfield, OH US
6/17/2019 11:10am
MotoMo165 wrote:
Anyone have experience with the wrench rabbits bottom end kit? Or know if any other year cranks/parts will fit in an 03? Hot rod doesn’t Make...
I dont think anyone here is going to tell you to get a hotrods or wiseco crankshaft. Buy a new oem or get yours rebuilt(which is cheaper btw)
6/17/2019 1:16pm
I have an OEM 03 CR250 crank that was pulled out of a good bike when I parted it out. No play in the bearing.
$50 + shipping?
Lasse
DK
6/18/2019 3:05am
In my book there is only one way to do it.
1. Print out a parts fiche.
2. Disassemble motor
3. Inspect parts
4. Circle parts needing replacement on the fiche
5. Pack up
6. Go to PC
7. Order circled parts
Post a reply to: CR250R Engine Rebuild Advice
