New Baltimore, MI, USA
10/27/2022 10:44am
I did the unthinkable last year and sold my Box Truck I converted into a hualer..
Now I need another for Vintage Racing and after looking at what's on the market I'm going in another direction.
So I found a 1996 Fleetwood 22ft Class C RV with 46k - figured this would be a great base to start with. The Fleetwoods offer steel framing in the rear and a compact design. It was clean, runs good and everything works.
1 - Cut the RV and save as much as possible - I want to reuse as much of the wood and cabinets so when Im finished it looks like it was built that way.
2 - Have the small rear garage hold 2 full size bike and have a flip down work area.
3 - Keep everything that works - Fridge, Bathroom, A/C unit, Genny and water.
But I was able to save most all the wood panel and cabinets., The refrigerator was the only thing that I was building around, the rest of the stuff can be moved.
The shower will be moved in the "garage" area and drain straight into the gray tank. I dont really camp of stay at the track so a "outdoor" wall shower in the garage will work fine for washing off after a mud race if needed.
The old walls were nothing more that 1 x 2's turned sideways with paneling on both sides (amazed they hold togther) - I was going to use 2x2 metal framing studs but they only had the 10ft lengths and I could not waste 3ft per stud as Im trying to do this for under 1000.00. So I went with 2x3's
Each joint was glued, screwed and plated - should be good.
The 12volt wiring was a trip.. I'm use to working on my boats and if a yellow wire with red strip leaves the panel (or switch) it suns that color till the fixture. not so with RVs - they used whatever color they had. Couple lights left the panel green/yellow and ended red, purple and I think a blue..
But you can see I used the old panel off the dinette set on this wall to "match"
Lots of L brackets have been used to offer extra support
The counter was also cut down and I was able to remove the back-splash, cut it and reuse.
Still on Budget $$
Plus, it seems they all leak in the overhead and start to delaminate, and I just didn't want to spend 20k on a project.
Its Vinyl laminate flooring (snap lock) - I used silicone to hold it down with a couple finish nails in each board. These style floors are designed to "float" but I found if you allow them to "float" on a RV or boat they just come apart, so I turned it into one big floor..
I'd vote for a basic wrap. Plain white does not look good with the windows, IMO.
The new couch is a FlexSteel with no room under it, so I needed to make room - First Furnace was removed. I don't like the idea of a little gas fireplace under a flammable couch ... so if I need heat I'll just plus in a small electric heater.
Next was the water tank.. thats going under the new counter.
I built a 4" base to raise the couch a little to clear the wheel-well and each section got 3 pcs of 1" hard insulation foam for sound and carpeted up 3 pcs of 3/8 for the couch to bolt to.
It will be a "wait and see" decision
I used Zinsser B-I-N Primer/sealer to give the new peel and stick wallpaper something clean to adhere to, the wallpaper was a "inexpensive" Amazon prime find.. doing my best to stay on budget.
Ramp style door off the side so I can re-use the old exterior wall, so everything matches.
or
Find or build a 36" door and screen and open up the existing entrance door..
Still lots of questions that need to be answered with this one..
The plus is the Fleetwood is a steel chassis and a little stronger than others (but its no box truck)
I removed almost 500lbs so far off the back end and Im watching the weight of everything that goes back in, plus the RV came with air shocks (bonus)
The wall was clean and primed before application and I really recommend this product! looks great and sticks like 3M on steroids. !
but if it comes apart, I'll redo it, it was only 75$
Post a reply to: Building a "Mini" - Fun Mover/Toy Hauler Class C RV
