Automatic trans fluid ?
Rick_Art
Oklahoma City, OK, USA
Edited Date/Time 12/26/2019 1:25am
For my crank case, 2002. Yz250. Can you guys tell me which kind would be ok ? Much thanx.
T-Fish
Sparta, WI, USA
12/18/2019 2:55pm
Ford ATF.
UGOTBIT
Upstate, NY, USA
12/18/2019 3:34pm
Type F user here
Rick_Art
12/18/2019 3:38pm
Ok thanks
Sachmo831
South Bend, IN, USA
12/19/2019 12:37pm
I had a kx250 that I ran type f atf in for a season. Atf is cheap but it never lasted long, within a couple ride days shifting would be more difficult and it would hit false neutral more frequently. I started running bel ray gearsaver and was much happier.
Rick_Art
12/19/2019 12:50pm
bvm111
Las Vegas, NV, USA
12/25/2019 3:16pm
I have used the HP gear oil for over 30 years in all my 2 strokes regardless of brand... it’s 7 bucks a quart and works awesome!
Rick_Art
12/25/2019 3:49pm
Yeah ! I'll get some, thanx !
Rick_Art
12/25/2019 4:29pm
One more question please, I'm an older guy, don't race, ...used to when I was young, I'm pretty mechanical, but I just keep this yz250 maintained. .. anyway, it has taken a whole quart. I just did it. Prior to that, drained the crank case. My manual says keep adding until it flows out. Is that right ? My gosh it must have been low. Haven't had this bike a real long time, and it's fast ! Should I keep pouring, until I see it comin out ? Thanx 😃
FGR01
12/25/2019 7:23pm
Rick_Art wrote:
One more question please, I'm an older guy, don't race, ...used to when I was young, I'm pretty mechanical, but I just keep this yz250 maintained...
Don't bother with the check screw. Drain completely and then put 750cc of oil in. Using the check screw can give misleading indications based on how fast or slow the oil levels out between the clutch cavity and the transmission cavity.
12/26/2019 1:25am
Sachmo831 wrote:
I had a kx250 that I ran type f atf in for a season. Atf is cheap but it never lasted long, within a couple ride...
I go half gear oil/half typeF. Because I had the same problem and this solved it.
Post a reply to: Automatic trans fluid ?
