Dearborn, MI
9/6/2019 8:22am
When putting the rear suspension back in my bike, what should I use to grease/lube the bolts.
Waterproof Marine Grease (The same as I used for the bearings)
or
Silver Anti-Seize (The stuff with a brush on the inside of the lid)
or
Check out the ARP website and see the difference in torque required using oil vs. moly paste.
KC
KC
Alternatively you can grease everything, except the threads and under the bolt/nut head (whatever is turning) and leave those dry. Then use the regular torque published in the manual.
Free shipping: VITALMX
https://m. https://youtu.be/Epbz8_x89ic
Post a reply to: Assembly Grease
