2019 KX450 footpeg bracket compatibility
Andy7
Venado Tuerto, Santa Fe, AR
Hi guys, I have a 2012 KXF450 and would like to know if the 2019 footpeg bracket bolts on. Has anyone tried this? Both parts number start with 32054, the 2012 part ends in 0054 and the 2019 one 0087. Does this mean that the only change is the color or are they any different? Thanks in advance
mx317
1/23/2019 8:56am
Andy7 wrote:
Hi guys, I have a 2012 KXF450 and would like to know if the 2019 footpeg bracket bolts on. Has anyone tried this? Both parts number...
The first part 32054 just tells it is a bracket, but the rest tells what it fits.
pCp 252
Hampden, MA, USA
1/23/2019 11:29am
I doubt it. The newer models have two optional mounting positions that the rider can select. One position being lower than the other. I think this started on the 14 450 models and the 15 250F models. I eyed the peg mounts up on the 19 450 at my dealer and I liked them. They looked like they would fit my newer Kx250f’s but the brackets from a 15 - 19 KX250F with the optional positions do not fit on the older frames like you have. Curious, why do you want to swap peg mounts?
Andy7
1/25/2019 2:57am
pCp 252 wrote:
I doubt it. The newer models have two optional mounting positions that the rider can select. One position being lower than the other. I think this...
The 450s have been adjustable since 2012, that's why I thought it was possible. I need to change one bracket as it is a little bent, and being the 2019 ones nicer than the older ones I just wanted to try.
crc245
Yorba Linda, CA, USA
1/25/2019 8:59am Edited Date/Time 1/25/2019 9:01am
2019's will fit. Different styling, but same dimensionally. Can even run the new 19' wider pegs on your 12' as they're a direct fit. May have to shorten the lower 8x25 bolt, as the 19's lost two threads at 8x23, but you should be fine.
Always wanted someone build these for KXF's in Ti when I had a Kawi, seeing that they'll fit a number of years, clean it up, and loose weight all at the same time...
https://racetechtitanium.com/product/titanium-kx250-450-foot-peg-mounts/
Post a reply to: 2019 KX450 footpeg bracket compatibility
