2001 CR250R suspension
ostach24
Hello all, I am restoring an 01 cr250 and need some help with the suspension. I need to know what years will fit if I buy newer forks and shock and what else I’ll need to get to make the forks work or anything I’ll have to go with the shock if I go the “newer” route.
If any one out there has something that would work please let me know.
erik_94COBRA
Houston-ish, TX, USA
9/27/2020 6:00pm
Forks up to 03 will fit without issue. The 03 also have larger base valves. The 04 and later have a different caliper bracket as the spacing changed.
Shocks are a little trickier as the lengths vary over the years and models.
All that to say, the stock stuff can probably be refreshed/revalved to be pretty good. If the stock parts are toast, only then would I want to mess with getting newer components fitted.
Carl 44
Sudbury, MA, USA
9/28/2020 4:56am
That was very good suspension, unless you are riding the pro class it would work great as it is. Just get it serviced.
JMCR250
Chesterfield, MO, USA
9/28/2020 6:09pm
I had an '00 and found the suspension, especially the forks, harsh. I sent them off to Factory Connection and it made a world of difference. It's good suspension, just needs some dial-in for your weight and riding style.
mxracer666
NE Iowa, IA, USA
9/28/2020 6:44pm
Thru 2007 CR250 will bolt right up, and are so much better that it's crazy. You will need a caliper bracket to fit the newer style fork lug spacing tho -- good time to upgrade to a 270mm oversize rotor and mount kit. front wheel and axle are same
H4L
9/29/2020 6:08am
mxracer666 wrote:
Thru 2007 CR250 will bolt right up, and are so much better that it's crazy. You will need a caliper bracket to fit the newer style...
Agree. I owned a brand new 01 model in the spring of that yr. & the suspension was ok.
OP - I have 07 CR250r suspension I’m selling. Let me know if you’re interested.
Post a reply to: 2001 CR250R suspension
