Grand Rapids, MI
2912th
5/20/2013 5:34pm
Hey guys I could use some advice. I've got a 2004 KX125 that's been sitting in my dad's garage since 2007. There were no issues last time in rode it in 07. But now the shifter won't shift. It will go from neutral to first and back to neutral, that's it. I think I'm going to split the cases myself but I don't really know what to even look for in there. Whatever went wrong happened when it was just sitting in the garage. Any ideas? Thanks I appreciate any help!
Once it finally shifted into gear , I then took it off the stand, rocking the bike while in gear, and it caught another gear. Rinse ,repeat, rinse ,repeat.Eventually ,it would shift through the whole range. Threw some oil in it, rode it a bit. A few more parts washer fluid rinses , and it shifted pretty good after a few more oil changes.
Start with the easy steps ,like motofab suggested. If the drain plug / washer fix does not help, the next step would be to pull the complete clutch cover side case ,and have a look at the shifting mechanism. Splitting cases would be a last resort.
Jake said it was hung in 4th gear and shifter was locked up. I just now noticed the metal in 2nd photo better go see what that is, maybe shifter rubbing screw for awhile but screw head doesn't look that beat up.
Post a reply to: Transmission problem
