Phoenix, AZ
4/3/2016 5:29pm
A CR250 I bought came a little low rear brake fluid. Brakes work just fine. Can I open the reservoir and just top off the brake fluid or do I need to bleed the brakes? The manual isn't very clear on whether just opening the cap and topping off is fine or not. Is bleeding the brakes only necessary if brakes are feeling mushy/not working very well?
Thanks.
Thanks.
First of all make sure you have the right fluid, prob dot 4 but make sure in the manual.
Take of master cylinder cap, get yourself a short piece of hose that you can put over the nipple of the bleeder that will reach a catch basin sitting on the floor.
With the hose on, and the cap removed, pump the brake lever and hold it. With your other hand if doing it yourself crack the bleeder and let the fluid run out into catch basin. Do not let go of the brake lever it will bottom out very quickly. Close the bleeder then release the brake lever. You will notice the master cylinder will be a little low on fluid, and keep repeating. Add fluid once there is room to add more.
After a few repetitions , you will effectively replace the fluid thruout the entire system, and your done!
Top off the master cylinder and replace the cap.
Simple as that!
Post a reply to: Refilling Rear Brake Fluid
