1/26/2012 6:50pm
Trying to help out a internetless friend. He has a 09 kx250f with very low compression....as in like 50psi. He tore the motor down and noticed his exhaust valves were open.....had a lot of carbon build up around them. He said his piston/cylinder (new at end of last season, not even ridden this season) looked to be in very good shape...no lines, gouges, nicks, etc. He cleaned everything up and put it back together and thats when he got the 50psi reading. I'm thinking it's the valves or springs that are worn and thats why the compression is so low. What do you guys think?? All help is much appreciated! BTW: I'm 4stroke illiterate!
Free shipping: VITALMX
The only true way to do it is with a leak down tester at TDC
Post a reply to: 09' KX250f - low compression
