East Bridgewater, MA, USA
1/27/2012 4:08am
i have a cr80. ive riden many bikes before but they were all 4 strokes. i only had about 5 chances to ride it before the snow came. the thing is an animal. but im haveing trouble in corners. if im not bogging im drifting and losing speed from loss of traction. anytips on how to carry speed with out the ass end sliding to much?
How tight is the corner?
And you need more than 5 lbs of air. 12-13 is typical.
I can't really pull the clutch with one finger so I put two on the lever when I think I might need to clutch. Try to stay in the right gear but sometimes you have to feather the clutch in turns, especially on 2-strokes.
if your getting too much power to the ground, just slip the clutch a little. The clutch is your best friend. It isn't only for getting power coming out but also for taming it as well.
Post a reply to: need help in corners
