Unknown starting problem
Dizzy86
Just bought a 2009 crf250 used (50hrs), got told it just had engine rebuilt while it got stroked to a 300. Went to start it for first time, only ever riding Yamaha,ktm this is first 4-stroke. I pulled yellow choke out all the way. Found the top on kick start. 5-min off kicking and no go. Tried with half choke next day, nothing, tried the advice on this forum & nothing. Took off seat, took off air filter & sprayed 1 sec of start ya bastard, put back together. No choke and kicked, it fired for 2- seconds then back to nothing. I’ve had it a week and havnt got it going once. The buyer is reliable but now overseas. Wat can I try before taking it to a shop and spending all that coin?
kb228
Mansfield, OH, USA
2/23/2019 12:01pm
Valves
gsxr6
Anderson, CA, USA
2/23/2019 12:14pm
Twist the throttle three or four times to squirt more fuel. Carb probably plugged from sitting
resetjet
Tampa, FL, USA
2/23/2019 1:04pm
Valves
babba boey
Kuna, ID, USA
2/23/2019 1:41pm
most likely clogged jet in carb or valve adjustment. If wasn't started after rebuild I would check cam timing. sounds like it is not getting fuel if it fired with starting fluid.
Post a reply to: Unknown starting problem
