South Jersey, NJ, USA
5/28/2019 10:00am
I’ve always wanted to rebuild a 125 2 stroke but I don’t have any experience with it or anything. I was thinking about buying a used/ cheap bike from Craigslist and buying a new top end rebuild kit and do some minor adjustments, clean it up, make it look nice, and probably keep or flip it. Should I go for it? Haven’t played with engines at all but I’m willing to learn and got the whole summer break coming up.
Careful on buying a cheap fixer-upper as it might need more than just a top end. Those projects have a way of expanding.
Check out all the build threads in the Bike Builds section here on Vital.
Free shipping: VITALMX
$1000 is running but probably trashed and on its past leg engine wise.
$2000 is a bike that was cared about and might need a top end or carb clean.
$2500+ usually is a nice bike that doesnt need much work aside some cleaning or tires or something.
Speaking in terms of a 125 2 stroke that is.
Be prepared for frustration and ordering parts you didn’t know you’d need. On the flip-side: it’s a great feeling every time you take it out, it’s noticeably a little better
Last month I was replacing linkage bearings and found out the swingarm bolt was sheared completely. The month before that I replaced the muffler packing and I’m pretty sure that’ll need to be replaced because the power valve is gummed up and blew oil out the can
As for cost, look in for sale section here, eBay, and only buy trick parts on holidays like Black Friday.
I can't tell you how much I wish I would have learned how to do a full bike back when. (And it is so much easier these days with all the online help!) Keep things clean, organized and take your time. I used to be such a fucking hack and my work got so much better when I slowed way down and stopped rushing through things. Do it, man!
Unless the guy has proof that everything was replaced recently and with OEM parts, I always plan for an entire rebuild.
I do appreciate the comments and tips though!
Post a reply to: First timer bike rebuild?
