Building the ultimate cr125 engine
Webby130
Hi all I’m looking to build a power house cr125 engine.
But I’m unsure we’re to start with what year engine
Or what year bottomend to topend I have been told a couple different ways to go.
First idea is
1996 cr125 bottomend with the 1996 cylinder
But usinging the 1998 cr125 power valves
Second idea
98 motor with Six speed box wider transfer ports standard than the earlier models and tune cylinder send it to Steve clithero
With an hpi ignition 37mm carb
Any comment I will read and take not of what the best idea is to get the most power out of a cr125 engine
9/12/2018 3:50pm
While the mid 90's engine have a strong reputation - I think people would be surprised just how good the 05-07 can be
We are working on a full works build 97 - custom mapped hpi to suit
But the base cylinder and engine in all stock, rebuilt form - only produced 30 hp on my dyno, it was quite sad vs modern engines
Webby130
9/12/2018 4:18pm
While the mid 90's engine have a strong reputation - I think people would be surprised just how good the 05-07 can be We are working...
So you are saying to build one with a 2005 to 2007 engine..?
9/12/2018 4:23pm
Depends on what your going for
If you already have an 05-07 - it may perform better than you'd expect vs transplanting a mid 90's engine and building that.
but - if you have a mid 90's engine - it CAN perform well too
CrGuy2T
Santa Fe, TX, USA
9/12/2018 7:12pm
Put a ktm or yz 125 motor In and save your self a lot of time and money.
12
Jrewing
9/12/2018 7:33pm Edited Date/Time 9/12/2018 7:34pm
What’s the weak link to the hpp? Power valve design, angled intake and air boot, short crank?
9/13/2018 8:15am
Most power improvements over the years has come from scavenging gains, its these gains that pushed the aprilia to 55 hp out of 125cc when honda was in the gps at 45
This is too hard to accurately describe in a short time - and as Ive seen on a T shirt that sums up my experience in (not) understanding this - I can (try) to explain it for you, but I cant understand it for you
2 strokes are insanely complex despite their mechanical simplicity - with enough time and effort most engines can produce good power - but some of that time and effort may also include some welding/redesigning of a lot of variables - and sometimes its not worth the time or money to make one project good
The hpp powervalve sucks
Rod length is similar to yz - usable, angled intake isnt ideal but can work ok for mx application.
Im working on one fairly heavily soon - with a goal around 40hp. All new stock with 4 different pipes tested it was 30... will be some hmwk to make it happen.
If I figure it all out - ill post some details
Jrewing
9/13/2018 1:48pm Edited Date/Time 9/13/2018 1:49pm
Well that's exactly where I'm at on my hpp 125. I love it but finding the competitive hp v cost/time debate is favouring another bike.
How much do TM144's Dyno at stock?
CrGuy2T
Santa Fe, TX, USA
9/13/2018 2:15pm
Scotty Haynes has the port maps for the plano Honda set up. Problem is have the pipe. Performance factory he’s in Dallas.
9/13/2018 3:38pm
Jrewing wrote:
Well that's exactly where I'm at on my hpp 125. I love it but finding the competitive hp v cost/time debate is favouring another bike. How...
A lot more than the honda Wink
We recently had the full PC team spec motor here at 33.5 or so on a 1991 If I remember right
It wouldn't be hard to be 35-36 - that's easy.
And the pipe thing - isn't too hard either - but to be where a modern ktm is at - would be nearly impossible
Jrewing
9/13/2018 4:15pm
A lot more than the honda ;) We recently had the full PC team spec motor here at 33.5 or so on a 1991 If I...
Well that's it. 35hp isn't going to pull my 84kg well enough against 65kg 250f riders. But I'm having fun trying.
Keen to follow your results with the modified CR project you're doing. Sounds like a lot of welding and devcon.
CrGuy2T
Santa Fe, TX, USA
9/13/2018 4:36pm Edited Date/Time 9/13/2018 4:36pm
Seems to be cheaper just put a ktm motor in it. Sadly I love Honda’s and that would be my next option. I just decided to go orange. Although, a ktm motor in a Honda frame would be the ultimate. Even today my 17’ 150 does not handle like a Honda cr 125.
Jrewing
9/13/2018 5:15pm
CrGuy2T wrote:
Seems to be cheaper just put a ktm motor in it. Sadly I love Honda’s and that would be my next option. I just decided to...
That's the other thing the Honda is my best handling bike I've had.
CrGuy2T
Santa Fe, TX, USA
9/13/2018 5:47pm
If I ever build another Honda I would just put a 15 Ktm 150 motor in and be done. You will spend more money trying to get that cr motor “any configuration” you and still it be close to what a Ktm 150 has to off and stock at that.
Jrewing
9/13/2018 7:05pm
CrGuy2T wrote:
If I ever build another Honda I would just put a 15 Ktm 150 motor in and be done. You will spend more money trying to...
Makes sense.
CrGuy2T
Santa Fe, TX, USA
9/13/2018 7:48pm
Jrewing wrote:
Makes sense.
I actually have a like new ktm 200sx motor on the bench. My wheels are now turning!
Jrewing
9/13/2018 8:36pm
Now you're talking!!
9/15/2018 11:08am
Jrewing wrote:
Makes sense.
the new 150 with minor work will outrun a 200 with significant work...
Just my thoughts.
CrGuy2T
Santa Fe, TX, USA
9/15/2018 11:38am
Just my thoughts.
The torque on the 200 is amazing. I don’t see that ever happening with a 150 motor maybe more top end I can see as the 20” is old technology. I would like to stroke my new 150 motor and see how that would work out. I kinda wish ktm would kept it a bore and a stroke.
9/15/2018 11:47am
Just my thoughts.
CrGuy2T wrote:
The torque on the 200 is amazing. I don’t see that ever happening with a 150 motor maybe more top end I can see as the...
It's the pipe - not the engine
build a longer pipe for the 150 - and you will shift the rpm range the same way
Jrewing
9/15/2018 2:08pm
Do you do custom pipes?
Webby130
9/15/2018 2:41pm
I picked up a 1995 cr125 complete engine today
What is the best mods to to this engine ....?
DynoDan22
Victorville, CA, USA
9/16/2018 12:39pm
Back in '93-94 I know the HPP factory Honda 125's were a hair over 40hp. Light years ahead of the others here in America. The amount of grinding and putty involved was pretty intense. I saw one of Henry's '94 cylinders and it was a work of art.
Jrewing
9/16/2018 1:51pm
DynoDan22 wrote:
Back in '93-94 I know the HPP factory Honda 125's were a hair over 40hp. Light years ahead of the others here in America. The amount...
Did they run powervalves
DynoDan22
9/16/2018 8:22pm
Yes. Fully functional HPP system.
9/16/2018 9:47pm
quite the improvement from the peak bikes in 91-92 then
Jrewing
9/16/2018 11:43pm
The mugwn cylinders are supposed to run very well. Never seen a set up one dynoed but Nino in Switzerland says his 125 runs as well as the ktms
DynoDan22
9/17/2018 6:38am
Derek, Yes. I think Mitch was around 35-36hp back then. The hardest thing when comparing HP numbers is figuring out what dyno the bike was run on and what correction factor was used. The difference between a Dynojet and a Superflow is pretty significant. Cliff White did some amazing things on those HPP valve 125's. They did machine all new power valve guides (taller) and EDM in taller bosses so they could raise the exhaust port significantly. if you raised the stock exhaust port that high on a stock cylinder, it would pass over the top of the valve guide and basically make the powervalve non-functional. I did see the dyno graphs and the torque was impressive.
9/17/2018 6:29pm
DynoDan22 wrote:
Derek, Yes. I think Mitch was around 35-36hp back then. The hardest thing when comparing HP numbers is figuring out what dyno the bike was run...
Bill (s Pipes) said Lammy's bike tickled 40 on their dyno in 97
But didn't comment on the power curve getting there which I still haven't seen a chart on.
The yamaha's 96 and on were clearly strong engines in SX and outdoors - which leads me to believe they had more from 9k-11k than the hondas
Post a reply to: Building the ultimate cr125 engine
