Yzf to yz suspension??
What do I have to do if anything to make the forks off my 23 yz250f work on a 23 yz125. I have some A kit stuff and was wondering if it would fit.
Thanks
3strokemx
1/6/2025 8:31am
Triple clamps, wheel, axle (and nut), bar mount assembly (with rubber inserts).
Maybe front fender too, or drill new holes if it doesn't line up.
1/6/2025 8:33am
What he said ^^ but I believe the steering stem length is also different so have those swapped out. Maybe Luxon can chime in & confirm
Luxon MX
San Diego, CA, USA
1/6/2025 5:02pm
If you're trying to bolt the four stroke fork to a two stroke, the easiest thing to do is shim the top clamp (needs a 1mm thick shim). Two stroke clamps use a 2mm larger diameter top clamp than four strokes.
The right thing to do is to swap triple clamps. You'll need the matching four stroke clamps, but you'll need to swap the two stroke stem into them. Yamaha is a nightmare with clamp fitment...
1/6/2025 5:42pm
Luxon MX wrote:
If you're trying to bolt the four stroke fork to a two stroke, the easiest thing to do is shim the top clamp (needs a 1mm...
Do I need a four stroke wheel and axle? I don’t need to do this but I have some A kit forks so I was thinking about throwing them on the 125
Luxon MX
San Diego, CA, USA
1/6/2025 5:47pm
hopsrev86 wrote:
Do I need a four stroke wheel and axle? I don’t need to do this but I have some A kit forks so I was thinking...
Not sure on the axle side, but you should be able to take some quick measurements to see if you have both bikes side by side.
cwtoyota
Tacoma, WA, USA
1/14/2025 12:24am
This is a bigger project than you may think.
Most late model Yamaha four stroke forks are longer than a two stroke.
They also have a larger axle diameter which requires a new hub and bearings or complete wheel.
The YZ125 and YZ250 handle best with the forks pulled up in the clamps a bit already, so it's likely you'll have to run the four stroke forks up against the handlebars or reduce the fork length.
You can shorten the forks by putting a spacer in the cartridge on the rod under the mid valve / rebound piston post.
You'll have to change the spring length or you'll go into substantially increased preload.
You can reduce the preload on the springs by relocating the spring perch clips or running shorter perches or fewer preload spacers.  What works depends on how the forks are currently setup.
Some kit forks have spring tubes depending on who built them...   You may not have room if there aren't already spacers without cutting down the spring tubes.
If you have both sets of forks side by side, compare length before you try to bolt them up and ride.
Post a reply to: Yzf to yz suspension??
