YZ125 Cylinder nuts keep coming loose
jridout12
IA US
I have a 21' Yz125 and I've got 60 hours on it. Did the first top end at 30 hours, everything looked good and put it back together. 15 hours later I had a bad coolant leak down the front of the motor just below the exhaust port. I chalked it up to a bad base gasket so when I tore everything down I noticed the cylinder nuts were all loose and barely finger tight. So I replaced the gasket and installed a new ring while I was in there and re torqued everything and put it back together. I have now gotten to the time to replace the top end again and upon tearing down I found the cylinder nuts loose again (not loose enough to leak coolant but for sure not to the torque spec). Is this a common issue with the Yz's? Or is there something I'm doing wrong? I may put a little loctite on the nuts to hopefully avoid this issue again.
seth505
SD, CA US
9/6/2023 6:56am
1) Are you sure you're torqueing them evenly and 2) Have you verified that the studs themselves aren't backing out?   Good luck
jridout12
IA US
9/6/2023 8:12am
Yes torqueing them in a criss cross pattern to the spec in the manual. And it did not appear that the studs are backing out
MxAddic
NY US
9/6/2023 10:23am
Internet rule #1. Don't ever post your nuts are loose.
Coughlin639
Clayton, NY US
9/6/2023 10:39am
Not sure what size the nuts are but look into replacing them with a mechanical lock nut, the type that has a crushed thread to help keep them tight. Or serrated flange nuts which bite into the cylinder to also help keep from backing off
silentDan86
Antioch, IL US
9/6/2023 12:37pm
Do yourself a favor and double check that those studs are tight.  I'm betting that is your issue.  I had a couple come loose on one of my YZs years ago.
wiedeman
Osceola, WI US
9/6/2023 3:39pm
I did a handful of top ends on an 09 yz 125, after 2 hours i would take the pipe back off and retorque all the base nuts. I could get atleast a 1/4 turn on each of them. If you aren't already, use a metal base gasket. I like the tusk ones, because they are cheap and have never failed me, and you don't have to scrape them off every top end.
kijen
Jacksonville, FL US
9/6/2023 5:29pm
Did you use new copper crush washers?
jridout12
IA US
9/7/2023 6:03am
This isn't on the head that I'm talking about. This is on the cylinder I don't think they had crush washers on those
FGR01
AZ US
9/7/2023 7:08am
Are you torqueing them to spec or doing it by feel?    I do it by feel and have never had 1 come loose.  But I've seen ones torqued to spec come loose.   I'd take it apart and check the studs as others have suggested.
BobDog
Tower , MN US
9/7/2023 8:19am
Check to see if the studs are stretching. Replace studs.
Post a reply to: YZ125 Cylinder nuts keep coming loose
