RM 125 suspension upgrade
chazhowson
Gp, AB, CA
So I am in the process of rebuilding my 2003 RM125, bike will be new from the ground up basically and I am wondering what the best route would be to go suspension wise. I can possibly by all the stock suspension components from an 08 rm 125 that from my understanding will basically bolt right up for the cost of about $1200 Canadian, this stuff is all in excellent shape and includes the triple clamps / front wheel. I would be about $800 upgrading my 03 stuff. Is there enough difference between the years to warrant the extra money? Or should I be looking at something else completely? Thanks guys
2/19/2024 7:14pm
The best suspension will be one that is sprung and valved for your weight, riding ability, riding type, and track conditions, that might be the rebuilt 2003 OEM suspension. Bushes, seals and oil is cheap.
RussB
2/20/2024 12:53am
Yes a 2008 front end would be an upgrade in many ways. The forks are better and are still considered good against most modern day forks, parts are still easily available and most tuners have good settings for the 08 model fork.
I believe the clamp offset is different (less) and the top mount features rubber mounted bars.
You will need to buy a new front brake line as the 08 fork doesn't support the under fork foot routing of the 2003. But this is also an improvement as its lighter, looks better and gives slightly better braking performance. You will also need to get new fork guards with the modern brake hose attachment (and a clamp). If you get the latest RM forks with the metal rings, you can ditch the nasty plastic fork guard guides which saves further weight and fork stiction.
You are a bit stuck with the rear shock as it's a different length to the 04+ RM shocks. But a good tuner will be able to get it working well (if it isn't already)
chazhowson
Gp, AB, CA
2/20/2024 6:23am
RussB wrote:
Yes a 2008 front end would be an upgrade in many ways. The forks are better and are still considered good against most modern day forks...
The rear shock length is different from 03 to 08? Didn't know that. Puts a damper in this plan as the guy doesn't want to sell everything separately just as a lot
RussB
2/20/2024 6:52am
Yeah, Suzuki updated the linkage for 04 and changed the shock to suit
garasaki
Mount Vernon, IA, USA
2/20/2024 1:35pm
Anyone know of any databases that would show rear shock length?
Was wondering this about an older model, 1998 specifically.
rm449
Pittsburgh, PA, USA
3/9/2024 3:15pm
MX Tech makes forks and a shock for the rm. That would be the best route but its expensive.
Post a reply to: RM 125 suspension upgrade
