Rich or lean bog
Zane
Castle Rock, CO, USA
In this video I’m purposely getting on the throttle real quick from low rpm in 2nd. I can’t tell if it’s to lean rich or if it’s just bogging because you can’t expect it rev up that low rpm on a 125. If I ride it like you should just 700 more rpm’s it feels pretty good. Maybe I’m just dumb🤷
https://youtube.com/shorts/T_3W4dOGd7U?feature=shared
Poll
Bog
Choices
Zane
10/3/2024 1:46pm
Also while I’m at it how long does a bike have to run before the spark plug reflects how it’s running?
MxAddic
10/3/2024 2:51pm
leaner than a peener...
Zane
10/3/2024 3:10pm
Thanks man. I went up 2 sizes on the pilot. My air filter is drying right now so once it’s back on I’ll see if I need to go richer on the pilot or move the clip from 3 to 4.
MxAddic
10/3/2024 4:10pm
Zane wrote:
Thanks man. I went up 2 sizes on the pilot. My air filter is drying right now so once it’s back on I’ll see if I...
Usually when it bogs like that you are only 1 away. GL!
Hcallz5
10/3/2024 6:36pm
What needle is in it
Zane
10/3/2024 7:22pm
A nozi needle out of a ktm. But I also have a 6.5 slide in there not the stock 7.0
Zane
10/4/2024 2:57pm
Still has the same bog I think I’ll go to clip 4 and see if that’s better.
MxAddic
10/4/2024 5:34pm
If it's unresponsive you have an air leak.
10/4/2024 5:45pm
this ^^^
Zane
10/4/2024 6:05pm
It only bogs if I slam on the thorottle from low rpms. Where would the air be leaking from? The reed cage?
Zane
10/4/2024 6:33pm
I just sprayed brake clean all over my carb while the bike was running. Nothing happened.
10/4/2024 6:42pm
It could be anywhere, left of right crank seal, between crankcases, base gasket, reed block, and or carb manifold, the only way to be sure is do a pressure test.
Zane
10/4/2024 7:22pm
Could the issue also be float height?
10/4/2024 9:10pm
Unlikely, but it's easy to check to eliminate as an issue
MxAddic
10/5/2024 5:55am
Just an educated guess but if I was you I would split the cases and replace the main bearings/seals. Upon disassembly inspect mating surfaces and you should be GTG..
Zane
10/5/2024 7:51am Edited Date/Time 10/5/2024 7:52am
I don’t think it’s an air leak because the piloit did change something. I’m just bad at jetting and didn’t  understand that the piloit isn’t what I needed to change. I can tell that I’m to rich of the crack of the throttle. Before I was making much better power super low.
FGR01
10/5/2024 1:29pm
You guys are running down all the rabbit holes.  Splitting cases.. hahaa.   You are too lean on your slide and needle, as Digger told you in the other thread.  And now you are trying to find workarounds such as richening the pilot.   But the root cause is already known.
MxAddic
10/11/2024 7:12am Edited Date/Time 10/11/2024 7:18am
FGR01 wrote:
You guys are running down all the rabbit holes.  Splitting cases.. hahaa.   You are too lean on your slide and needle, as Digger told you...
Yeah, an air leak causing him to be lean on the slide and needle, imagine that.
if he wasn't leaking going up 2 on the pilot would have paved oven that lean spot like a parking lot over paradise.
FGR01
10/11/2024 9:43am
MxAddic wrote:
Yeah, an air leak causing him to be lean on the slide and needle, imagine that.if he wasn't leaking going up 2 on the pilot would...
Read his other posts in other threads.   Digger gave him specific slide and needles to use.  He got leaner versions than those.  Now he's wondering why the bike is lean.   This is a more likely cause than he developed an air leak between the cases and needs to split them, especially considering we're talking a 1-2 yr old bike here, not some clapped out 20 yr old bike.  When troubleshooting it's important to understand the history and previous steps taken and apply common sense to follow the most likely causes first before resorting to the most unlikely.
Zane
10/11/2024 10:11am
I’m back on the 7.0 slide and a a needle a lot my similar to stock and I’m still have that same problem.
MxAddic
10/11/2024 10:23am
FGR01 wrote:
Read his other posts in other threads.   Digger gave him specific slide and needles to use.  He got leaner versions than those.  Now he's wondering...
"I’m back on the 7.0 slide and a a needle a lot my similar to stock and I’m still have that same problem."
LMFAO!
FGR01
10/11/2024 10:32am
LMFAO!
Yes, because the 7.0 is even leaner than the 6.5.   Also, we have no idea what the rest of the settings are he's trying with this 7.0 slide.
MxAddic
10/11/2024 12:19pm Edited Date/Time 10/11/2024 12:24pm
FGR01 wrote:
Yes, because the 7.0 is even leaner than the 6.5.   Also, we have no idea what the rest of the settings are he's trying with...
Get back to me when all the internet jetting experts figure it out...
If you think it's bogging like that with the stock slide and one richer I got nothing for you.
FGR01
10/11/2024 1:16pm
MxAddic wrote:
Get back to me when all the internet jetting experts figure it out...If you think it's bogging like that with the stock slide and one richer...
Have you ever jetted or even ridden a new gen YZ125?   Get back with me when he splits the cases, cures his bogging and proves you right.
MxAddic
10/11/2024 2:48pm
FGR01 wrote:
Have you ever jetted or even ridden a new gen YZ125?   Get back with me when he splits the cases, cures his bogging and proves...
I just might do that. You seemingly think there is something special about the running characteristics of new gen YZ125 than every other 2 stroke ever built.
Alex814
10/11/2024 6:31pm
MxAddic wrote:
I just might do that. You seemingly think there is something special about the running characteristics of new gen YZ125 than every other 2 stroke ever...
These bikes are especially susceptible to this type of bog due to the stock #7 slide. As soon as you go a step or two leaner on the stock 75 pilot it will likely bog.
Put the complete stock jetting back in the bike and test again.
Zane
1/12/2025 9:12pm
I had gone riding in Texas and it was super muddy my bike was still acting up. I think it might be my clutch because I’m ringing it out and I’m going no where but it might have been wheel spin because of mud but I don’t think so. While higher in rpm’s it almost sounds like a rev limiter https://m.youtube.com/watch?v=C75ews2957c at 2 minutes you can hear it. Also my Jeting should be plenty rich 172m 48p 7slide and nydf clip 4
Zane
1/12/2025 9:13pm
Also I was lugging it around a lot on purpose because of traction and the issue I mentioned.
Alex814
1/13/2025 1:46pm
Zane wrote:
I had gone riding in Texas and it was super muddy my bike was still acting up. I think it might be my clutch because I’m...
Again, I think your 48 pilot is way too lean. Try a 68 if you're sticking with that slide and needle and drop the main a couple sizes to compensate.
Zane
1/13/2025 3:23pm
Ok I will. But I wouldn’t think the pilot would make the bike not accelerate even though I’m reving up and the rev limiter sound.
Post a reply to: Rich or lean bog
