MC350/FC350 compatibility
cwel11
Orangeville, PA, USA
Edited Date/Time 4/25/2023 6:15am
Does anyone know what parts (if any) are interchangeable from 22FC350 to a 23MC350? Ideally forks, levers, vortex, wheels, and seat would be nice.
wrc777
Greenwood, IN, USA
4/25/2023 6:21am
Seat won't fit at all. It has a completely different mounting system. FC350 stock forks are 10mm shorter (linkage and shock are a little different too) than KTM/gasgas in 21-24. Plastics, subframe, and fuel tank are completely different too.
Everything else should fit assuming both have Brembo master cylinders. I heard some gasgas were shipping with braketec. If so the levers probably won't fit.
ECU tuning might be a little different depending on the tuner who put the maps in. Contact the specific tuner to find out.
FGR01
4/25/2023 6:21am
22-FC forks are shorter and not a direct swap.   You can swap the forks over if you also do the shock and linkage but then the MC will be short just like the FC.
Brake lever will swap as long as the MC is not the BT (BrakeTec) model bike.  Clutch....  did the 2022 FC got o a Brembo master?  I only have 20/21 FC's here which all have Magura masters that won't swap to an MC.
Vortex should swap direct with same mapping.  If you look at the sheet from XPR I believe it lists all the model 350's it is mapped for.
Wheels -direct.
Seat -no chance.
FGR01
4/25/2023 6:22am
wrc777 wrote:
Seat won't fit at all. It has a completely different mounting system. FC350 stock forks are 10mm shorter (linkage and shock are a little different too)...
Holeshot!!
wrc777
Greenwood, IN, USA
4/25/2023 8:04am
FGR01 wrote:
Holeshot!!
Haha got ya!
cwel11
4/25/2023 9:21am
Thanks guys. 22 FC is all Brembo. Running ARCs and like to keep them. I have the ohlins spring conversion and like the lowered Husky so I’d probably swap out suspension. I sent an email to XPR to double check on the ecu. Thanks again 👍🏻
wrc777
Greenwood, IN, USA
4/25/2023 11:44am
You will have to check part numbers and see how much of the linkage and knuckle you need to transfer but it should all bolt up the the gasgas. Did ohlins shorten the fork and make the shock changes to work with the lowered husky?
cwel11
4/26/2023 3:05am
wrc777 wrote:
You will have to check part numbers and see how much of the linkage and knuckle you need to transfer but it should all bolt up...
I just have the Ohlins internals
Post a reply to: MC350/FC350 compatibility
