KTM s spring weight chart ?
MX558
Edited Date/Time 2/24/2024 6:23am
They give you weight charts for the rear spring in the manual so I'm wondering if it's with gear or without, it doesn't say . I have a 22 350 and am 180 with out gear . Thanks
MX558
2/24/2024 8:39am
Oh I should note I can get ok sag numbers in the perimeter with both OEM and 4.5  springs
FGR01
AZ US
2/24/2024 12:25pm
I think they are meant for "total weight" as in with gear.   At 180 you are same size as me.  We are pretty borderline between a 45 or 48Nm on that 350.  I am running a 45 on mine and happy with it.  Some guys might prefer a 48.
aees
2/24/2024 1:22pm
Its truly a preference question. Are you tall? Then most likely go up.
I'm 200, running 48, get pretty much 38/104, or 40/106 with 6-7mm preload. 450 2022.
35-36 on OEM shock is low = go up so you get 37-40 at least. Even 37 on rough track is a bit low.
MX558
2/24/2024 1:56pm
FGR01 wrote:
I think they are meant for "total weight" as in with gear.   At 180 you are same size as me.  We are pretty borderline between a...
I just had the forks softened up Kyb spring conversation and now seems a little out of balance with rear too stiff . My sag is 40\ 105 with very little preload on the spring .
FGR01
AZ US
2/24/2024 3:55pm
MX558 wrote:
I just had the forks softened up Kyb spring conversation and now seems a little out of balance with rear too stiff . My sag is...
Measure the spring compressed length to know exactly how much preload you have.   The Austrian bikes don't use a whole lot of preload to begin with.  They call for 7mm as nominal and basically you don't want to get outside of about 5-10mm ideally.   I'm generally running 8-9mm of preload with the 45Nm spring.
MX558
2/24/2024 6:29pm
FGR01 wrote:
Measure the spring compressed length to know exactly how much preload you have.   The Austrian bikes don't use a whole lot of preload to begin with. ...
Thanks , I'm riding tomorrow to see how it goes
cwel11
Orangeville, PA US
2/25/2024 3:40am
Same bike (23 mc350) same approximate weight. I ran the stock 4.2 with good sag numbers but now that the bike has broken in I’ve started getting more fender tire rub and have now gone to the 4.5 which I always ran on my 22 FC350. Depending on your gear and speed you may have to bump up one spring.
MX558
2/25/2024 6:10am
cwel11 wrote:
Same bike (23 mc350) same approximate weight. I ran the stock 4.2 with good sag numbers but now that the bike has broken in I’ve started...
I have 4.5 on now and hardly ever get fender rub . I am 59 and vet intermediate speed I guess
cwel11
Orangeville, PA US
2/25/2024 9:15am
Your sag numbers should be good then I’d guess
FahQ
NJ US
2/25/2024 9:21am
IMG 3381.png?VersionId=I2mr.lzLxrFkFrh
aees
2/25/2024 3:06pm
Then go down a spring rate if you feel balance is off. You can run 38/105 with softer spring and get more preload on it.
MX558
2/25/2024 3:36pm
Rode today on a good track with a mix of everything. The bike worked pretty well . My sag in gear 40 -105 the bike was pretty good . I think I might try lighter spring just for the hell of it . I will say now that I softened the forks they work awesome. Thanks for all the help guys
FGR01
AZ US
2/25/2024 6:25pm
Adding this.. before you swap springs again, try opening the HSC on the shock about 1/8 or 1/4 turn.  It has quite an impact on bike attitude and balance.
Post a reply to: KTM s spring weight chart ?
