How long do rear wheel bearings last?
Gator 4
Southern California, CA, USA
Do they last forever?  Bike is a 125, 10 years old.  Wheel spins fine.  I popped one of the seals off and the bearing had plenty of grease in it still, no signs of water or grit.  Just curious if anyone has long term experience.
RussB
6/5/2024 3:13am
If you are sensible with your pressure washing and don't ride in overly aggressive and nasty conditions then they can last a very long time. But they wont last forever.
The best way to test for wear and function is just to stick a finger in the bearing when the wheels out and slowly rotate. If its quiet and completely smooth to turn then you're good to go. But if they sound dry or notch at all during the rotation then its time to swap them out
CodyC
Morgantown, WV, USA
6/5/2024 6:38am
It really depends on the conditions.  Lots of mud and/or sand will kill them faster.  Bad pressure washing can also really hurt them.  I always put it on a stand and rock the wheel side to side, if there is play I replace them.
You can look up the sizes, buy cheapo bearings on eBay and then just replace them faster.  I kinda like changing them more with a slightly-less good bearing. They really don't take long to replace and when you do just carefully tap them in and use plenty of good waterproof grease.
6/5/2024 9:12am
The original ones that came in my Talon hubs lasted about two years/60-70 hours. They went out and I used a set of All balls in a pinch that were literally toast after a 2 hour harescramble. Took my originals to a local bearing house, old school guy runs the place and brought out three bearings and said I can sell you a $6 bearing, a $30 bearing, or a $60 bearing and they’ll all last the same amount of time if you’re not shielding it with a quality seal. Then he brought out a few different seals and showed me the difference in construction and quality of materials used. Went with the $6 bearings and the more expensive seals ($8-10 a piece maybe?) and haven’t touched them since. Been 5 years and 100+ hours and they still spin like new.
sandman768
Saratoga Springs, NY, USA
6/5/2024 9:52am
Loaded question, lots of variables… I had to replace a set of oem honda rear wheel bearings once due to the previous owner felt he needed to tighten down the rear axle nut like it was on a  Mack truck…squished the distance tube & put too much pressure on the bearings….as others have stated, the pressure washer can do more damage than good when it comes to bearings….
CodyC
Morgantown, WV, USA
6/5/2024 2:50pm Edited Date/Time 6/5/2024 2:53pm
sandman768 wrote:
Loaded question, lots of variables… I had to replace a set of oem honda rear wheel bearings once due to the previous owner felt he needed...
Very good point, you gotta watch the torque spec on the axles, people tighten them down waaaay too far.
Moto520
Schaumburg, IL, USA
6/5/2024 6:14pm
It’s super easy to replace the bearings on these bikes.  I would say that a wheel bearing should last 130 hours.  I think that’s a good number
TooOld4WFO
Fresno, CA, USA
6/6/2024 9:50am
I don’t believe you can overstate the issue Sandman and Cody observed. Every used bike I have restored has had this issue. That tube when compressed against both inner races dramatically affects those bearings in movement.
Moto520
Schaumburg, IL, USA
3/15/2025 2:19pm
Anyone know how to change the rear bearing on a Faster USA Ktm hub?
3/16/2025 8:05am
What’s different about it?
FGR01
3/16/2025 9:37am
2 bearings on drive side.  Stock is only 1.
Moto520
Schaumburg, IL, USA
3/16/2025 10:01am
On the stock Ktm….you can push the center spacer aside and hit the edge of the bearing to pop it out.  On the faster USA hub…..the spacer doesn’t move
FGR01
3/16/2025 11:45am
Moto520 wrote:
On the stock Ktm….you can push the center spacer aside and hit the edge of the bearing to pop it out.  On the faster USA hub…..the...
Give Collin a call at Faster and he'll give you the straight info on how to deal with it.  Ideally you'd use a slide hammer bearing puller but he might be able to tell you some alternatives.
3/16/2025 3:51pm Edited Date/Time 3/16/2025 3:51pm
Heat and slide hammer sounds like the procedure, but call Faster anyway. They’re great and may have a secret method.
MotoDad32
Beverly Hills, CA, USA
3/17/2025 4:56am
I just replaced a set in my FasterUSA wheel last week, and that's exactly the process I used.  I'm guessing the tube is 'squished' a bit too much and it's difficult for you to push the spacer aside - a bit more elbow grease is what I'd suggest and replace the tube afterwards.  Alternatively, a blind bearing puller like this may help:
Falcon
Menifee, CA, USA
3/18/2025 3:27pm
The bearings in my '06 YZ250 lasted from the day I bought the machine new until I sold it a month or 2 ago. So, that's 19 years and probably 1,000 hours.
I pulled the dust seals off and added grease a few times, but that's it. Never point the power washer at the hub; only the tire/rim. I get in between the spokes with a sponge instead.
Moto520
Schaumburg, IL, USA
3/18/2025 7:20pm
Hey man……thanks guys!  Good info
Post a reply to: How long do rear wheel bearings last?
