I’m rebuilding some wp Kyb forks converted by Enzo with the national spring tubes tuned for MX. I know oil amounts vary but what’s a ballpark to start with? I’ve seen anywhere from 260-330cc. Unfortunately no sticker on the forks detailing the settings.
Are you rebuilding them for yourself? Then I’d start with the lower number and just add as needed. If it’s for a friend I’d just put it in the middle of those two numbers and tell them how to add and adjust. It’s just oil. Its gonna be obvious if it’s too soft.
25-30 less that normal. 325 good number that won't be more that +-10ml off, if it ain't spot on.
320 is my oil amount from Enzo with pro circuit national spring tubes valved for moto vet B
That's quiet high, same level as with normal spring perches. What bike and weight?
22 ktm 350sxf
22 ktm 350sxf
thats what’s on the build spec sheet from Enzo 🤷🏻♂️
My recommended level from Enzo on my RMZ KYB forks is 340ml. That was when I switched to softer springs, 145lb B moto.
Ok great, thanks! Maybe the option is to run same spring rate, 350ml. Some go up one spring rate (5.0 to 5.1) when they run spring tubes to get it plusher, and then maybe they drop oil a bit.
Post a reply to: Enzo WP/KYB oil amount
