Crank Bearing fit
Should crank bearings be a press fit onto the crankshaft? If they slide on with a snug fit is that going to be an issue? I know if they are not tight in the cases they will spin and that turns into an issue.
Banana_oil
Gothenburg, SE
5/2/2026 7:09am
I have noticed a difference between brands. My cr125s have press fit while yz have snug fit so probably normal.
5/2/2026 11:48am
1996, 1997, 2000 Rm125s
Nairb#70
Ivoryton, CT, USA
5/2/2026 1:34pm
Do those cases have steel press in inserts for the main brgs.?
5/2/2026 2:17pm
I’m talking about the crank bearings around the OD of the crankshaft
5/2/2026 5:53pm
I think he's asking if the case's main bearing cavities have been sleeved, that's one solution if the bearings are spinning in the cases.
The bearings should be a "press fit", I normally put the bearings in the freezer, heat the cases and the bearing drop straight in, if they slide in at normal temperatures there is an issue.
Banana_oil
Gothenburg, SE
5/2/2026 10:34pm
I think he's asking if the case's main bearing cavities have been sleeved, that's one solution if the bearings are spinning in the cases.The bearings should...
Agree! I thought you meant on the crankshaft.
5/3/2026 5:48am
It should be a press fit usually I did my yz with parts at room temp and pulled the crank in with a puller
5/3/2026 6:41am
I did mean on the crankshaft……not the cases.
40acres
Houston, TX, USA
5/4/2026 7:13am
Yes, they are press fit using a crank puller on each side to install.
Post a reply to: Crank Bearing fit
