2023 to 2021 KTM Rear Wheel Conversion
DaBaum44
What's up Vital. I'm in the process of moving parts to and from my 2023 and 2021 KTM 350 SX-F.
Can anyone confirm the OEM parts I will need to convert the 2023 rear wheel onto my 2021? As far as I know, I will just need to buy the 2019-2022 style center hub collett, seals, and spacers, due to the larger axle.
I put the Dubya wheels from my 2021 onto the 2023 and that was a simple rear spacer swap. Thanks in advance.
DaBaum44
12/15/2022 6:17pm
12/15/2022 9:02pm
I just converted my 2023 XC rear wheel onto my 2022 XC. I can confirm 3,6,7 is what you need.
DaBaum44
12/16/2022 3:59pm
Were you able to re-use the wheel bearings? I have a blind bearing puller so I hope that it doesn't do any damage pulling the one side out.
12/16/2022 6:17pm
DaBaum44 wrote:
Were you able to re-use the wheel bearings? I have a blind bearing puller so I hope that it doesn't do any damage pulling the one...
Yes, I heated up the hub and used a blind bearing puller. I only removed the non drive side bearing.
wr74
12/29/2022 6:30pm
Ktm sells a conversion spacer that slips straight in, so no need to replace the bearings or any other parts.
12/30/2022 9:24am
Wrong. The 2023 inner spacer is made for the new 22mm axle. The 2021 25mm axle does not fit through the 2023 spacer - I have tried it as previously mentioned.
Did you read the OP title wrong ?
151
Olive Branch, MS, USA
1/25/2023 10:46am
Same situation, same project.
Aren't all the parts needed included with the 2023 bike?  Is it possible to just use the center spacer bearing and seal from my oem 2023 wheel in my 2022 Dubya wheel?
Post a reply to: 2023 to 2021 KTM Rear Wheel Conversion
