2017 YZ125 Nikasil coating
murph146
Brewerton, NY, USA
Doing my 2nd top end, bought the bike used and immediately did a top end to be sure and the cyl was fine. Now 30hrs later it seems some of the Nikasil has gone away. Only in this spot though. Am I ok for another 30 hours? After this rebuild I do plan on sending it out for coating. I did measure the top, middle and lower and the cylinder is still in spec for "b". Thoughts and thank you!
Wiscomx
West Bend, WI, USA
7/12/2024 4:21am
Your call, I would send it out to get repaired, might save you some headache and money in the long run
sandman768
Saratoga Springs, NY, USA
7/12/2024 5:21am
Did someone run a hone through that cylinder? Cross hatching looks aggressive?
Tryhard
7/13/2024 8:35am
I'm going to 2nd that , with it being at the bridge I wouldn't chance it.
murph146
Brewerton, NY, USA
7/13/2024 3:26pm
Yes the cross hatch was my doing. Ran an oiled ball hone with a drill at low speed 6 times in each direction. Yes I know there a huge debate to do or not do this method. I did this when I put the 1st piston in so the wear my have been my doing.
Thanks for the replies, ended up ordering a new cyclinder. I am going to send the old one out for plating, wasn't expecting to have a jug in rotation but I guess I do now!
Post a reply to: 2017 YZ125 Nikasil coating
