2017 KTM 350SX absolutely SHREDDING!
DF313
Ogden, UT, USA
...itself apart from the inside...
Changed the oil and found loads and LOADS of non magnetic, large, shreds of metal.  I will open it up and see what's going on, but I was curious if anybody knows what type of gasket came on these motors to mate the engine cases from the factory?  It looks to have an RTV type gasket on it, I was just trying to estimate if it had been opened at any point by a previous owner.  Thanks!
RockyRider
Nor Cal, CA, USA
2/14/2024 9:52am
They have no case gasket, just RTV like you see
YZed250
Costa Mesa, CA, USA
2/14/2024 10:27am
DF313 wrote:
...itself apart from the inside...   Changed the oil and found loads and LOADS of non magnetic, large, shreds of metal.  I will open it up and...
These engines are very reliable ... the only exception is the oiling system.. see idler gear failure. Usually leads to seizure and not large amounts of metal debris. Almost sounds like you lost a bearing (crank, trans etc).
DF313
Ogden, UT, USA
2/14/2024 11:27am
thank you, I thought it looked too good to be a nonfactory rtv job.  I suspect it has not been open, but at 240 hours, I think it (obviously) past due
DF313
Ogden, UT, USA
2/14/2024 11:32am
YZed250 wrote:
These engines are very reliable ... the only exception is the oiling system.. see idler gear failure. Usually leads to seizure and not large amounts of...
Yeah I am curious, what it is.  Of course I bought the bike from the typical suspect, "regular oil changes, trail rides, ect ect" and it did run, look, and sound great, even when I drained the oil nothing alarming came out, but upon looking in the hole for the oil screen, it was unreal, probably a good couple teaspoons full of large silver, non magnetic shavings in that little bottom area.  But, I knew what i was buying and with the amount of hours on the bike I knew a full rebuild was coming sooner than later, just not this soon.  I will update this once its open.
Kidkawie
ქუთაისი, GE
2/16/2024 12:20pm
Do not use RTV silicone.
Use a case sealer, Yamabond, Kawasaki bond, 3bond, etc.
DF313
Ogden, UT, USA
2/21/2024 1:44pm
the workshop manual recommends Loctite 5910.  I would assume that should work?  Unless somebody feels strongly otherwise?
DF313
Ogden, UT, USA
2/21/2024 2:07pm
So I found out what had been happening
The left hand thread nut that holds the primary gear in pace was coming off and spinning against the inside of the inner clutch cover.  That also allowed the primary gear to float up and rub on the cover as well.  Glad I caught it now, based on the pictures I don't know how much longer it would have lasted without total failure.  The snap ring just fell out, there was nothing left for it to snap into!20240221 094454%5B1%5D
YZed250
Costa Mesa, CA, USA
2/21/2024 2:17pm
Great catch!
I seem to recall the primary gear coming loose on my YZ250 and trying to exit the clutch cover in a similar fashion, ha ha!
sandman768
Saratoga Springs, NY, USA
2/21/2024 3:48pm
Red loctite that prick back on….Good catch…had that happen to one of my RM250”s after a rebuild…
Post a reply to: 2017 KTM 350SX absolutely SHREDDING!
